Reset CMOS emachine M5312 notebook access instructions
Hi experts I need to access the motherboard on my laptop so I can re-set CMOS to change BIOS I can't get to the BIOS settings anymore? I can't get past the boot process via the delete button during start-up. I've done Insert key while boot-up method to no avail. I know the RAM is okay, but I'm having problems getting inside to the of notebook, is there a trick to this? I know about all the grounding myself techniques, I've done desktops before, but notebooks are obviously different, I have the screws out of the bottom but can't seem access inside, I don't want to force it. HELP! thanks ahead of time for your expertise on my dilemma, Michael imhookt1@yahoo.com
  • Michael Deutsch
    Michael Deutsch Aug 22, 2008
    thanks tbird, I'll give it try, I'll let ya' know, "Hook" meanwhile check out my documentary at michaelthehookdeutsch dot com you'll dig it I'm a multi-award winning 1 handed, 1 hooked keyboardist, enjoy
  • 3,051 Answers
You should have a strip above the keyboard that needs to come off gently pry it up and off then you will see yhe screws that hold on the keyboard and the cdrom if you remove them and lift off the keyboard the rest of the motherboard will be exposed for removal
Posted on Aug 22, 2008
Emachines bios password need to bott from CD but cannot enter bios to change boot order.
inside the computer on the motherboard there is a cmos jumper. look for this and read the instructions by it to clear the password and settings. also pull the coin cell battery from the unit. this will defautl the motherboard settings. you will have to reset the time and then you can change the boot order.
Sep 26, 2011 | E-Machines eMachines Desktop PC
Tip
Resetting BIOS password
If you have loast the password, to reset the BIOS password you need to remove temporarily the CMOS battery , so to reset BIOS settings.
Some model may be using NV Ram, in that case removing the battery is not enough.
The battery is located on the lower side on the motherboard.
On many DELL models the battery can be accessed from the side of DVD slot, battery slot, or RAM slot, without disassemblying the laptop.
On some model you may need complete disassembly (eg. Dell Le series).
The battery usually looks like a couple of coin batteries wrapped in plastic and connected to motherboard by a two wires connector.
Before disassemblying or removing covers, always unplug adapter and remove battery.
Several Dell Laptop can be set to use NV Ram to store the password.
In this case the problem cannot be solved removing primary battery, then accessing and removing CMOS battery for few minutes.
If you still cannot reset you have two way out.
Disassemble completely and access the NVRAM microswitch, or contact Dell and get master password.
You can also try one of this standard Dell factory CMOS password:
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Dell
on Sep 11, 2009 | Dell Inspiron 8500 Notebook
I want to that how i reset my recovery password and where the actual location of CMOS Battery?
In computing, BIOS (basic input output settings) refers to the information stored regarding a computer's hardware configuration, the system date and time and any applied password. This information is known as the BIOS or CMOS settings--the BIOS is stored on a small battery-powered semiconductor chip known as the CMOS (complementary metal oxide semiconductor). Having a CMOS or BIOS password restricts unauthorized changes to the system's hardware configuration and, in some computers, may even be required for booting. A lost password may be reset by removing the CMOS battery, clearing the motherboard jumper or using a software-based password cracker.
Removing CMOS Battery
1. Shut down the laptop and unplug its power cord from the wall outlet. Remove the battery cover under the laptop and gently raise the battery from its dock. Unplug any peripheral devices with a live power source connected to the laptop, such as a modem or printer.
2. Locate and remove the CMOS battery. Refer to your user manual or visit the manufacturer's website for your laptop's architecture. Follow manufacturer recommended procedure to access and remove the CMOS battery. Depending on make and model, this procedure may be more involved for some laptops and not others. The CMOS battery is a flat circular shape and resembles a watch battery.
3. Wait 30 minutes and then put the battery back in. This will erase all information stored in BIOS. Assemble the laptop, making sure you leave no loose connections. Power up the laptop and press "F1" when you get the "CMOS cheksum error" message. Type in a new password.
Clearing CMOS Jumper
1.Turn off the laptop and access the motherboard following recommended procedures.
2.Locate the jumper in the motherboard. If you do not have your motherboard documentation, locate a single jumper near the CMOS battery. In some laptops, the jumper may also be labeled in the motherboard. Put the jumper setting to "Clear" and reassemble the laptop.
3.Turn on the computer and hit "F1" when the "CMOS checksum error" message is displayed. Navigate through the BIOS settings interface to load default settings and apply a new password.
Using Password Remover
1.Download a software-based BIOS password cracker. There are numerous free programs able to recover or delete CMOS or BIOS passwords from virtually all motherboard brands. Download the file from a trusted source and save it to the desktop.
2.Burn the installed file to a CD using image burner software. Insert the CD and access the password remover tool.
3.Note the password or use the program to set a new password.
I hope you find it very helpful. Thank you for using fixya.
Aug 15, 2011 | IBM Lenovo IdeaPad Y560 Notebook
I need to rest password in bios
Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes all passwords and CMOS settings to be cleared. BIOS password can be removed by temporarily disconnecting/ removing the RTC/ CMOS (Coin-cell) battery from the motherboard.
Disconnect the coin-cell battery from the system board and it will reset the BIOS to its default setting and the password would be gone.
Please Refer to Page 29, 106 & 79 of the REPAIR MANUAL IBM T40 for Battery removal, keyboard removal and RTC battery removal instructions.
The Backup Battery (RTC, CMOS) is located under the keyboard. So you have to remove the keyboard to access the battery. The above Manual from IBM shows the exact method/ instructions and pictures for laptop dis-assembly for the purpose.
If you are comfortable with working inside such electronics, you can't do it yourself, or else you may seek help from local laptop service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | IBM ThinkPad T40 2373 Notebook
My emachine notebook is need to reformat but the bios has a password and i forgot it. i need to clear the cmos but mi cant find the internal battery.what the best solution in this problem? please help
To reset the BIOS password read the information from this link http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
In case of your laptop I would suggest using software from Hiren's Boot CD to clear the BIOS (there's Kill CMOS on there that wipes the BIOS).
Jan 21, 2011 | E-Machines M5312 Notebook
Hello how to reset bios password of ibm thinkpad t23 2647
To unlock the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Take care.
Nov 19, 2010 | IBM ThinkPad T23 2647 Notebook
How can you reset a Precision M70 Laptop bios password
For that you need to reset bios password.
There is 2 way (1) Reset bios password with cmos cell and jumper settings.For that you need to open back cover of laptop then find motherboard pull cmos cell from motherboard for 10 minutes then reattach it into it's position.There jumper near cmos cell named clear_cmos it has 3 pins 1-2-3 put jumper in 2-3 position then power up then again put it into it;s original position 1-2 then all password RESET.
(2) you can RESET bios password with software download it from below link.
Click here
Click on above link download software there is instruction how to reset bios password.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Dell Precision M70 Notebook
How do I clear the BIOS drive lock on eMachine notebook M5312
you can't. you need to replace the hard drive, that's the solution. there's no easy way around this feature.. it's specifically desiged so if the computer is stolen the drive becomes inaccesible.
Mar 26, 2010 | E-Machines M5312 Notebook
Need to unlock bios password on dell laptop, have service tag # and ends in 59b
The battery looks like a couple of coin batteries wrapped in plastic.
On Dell Inspiron 8500 the battery can be accessed from a side , after removing the primary battery.
I think Dell 8500 can be set to use NV Ram to store the password.
ALFAROME
BIOSTAR
biostar
biosstar
CMOS
cmos
LKWPETER
lkwpeter
setup
SETUP
Syxz
Wodj
Dell
My laptop, emachine m5312 shuts down by itself despite the power settings to stay on, any ideas?
it may be set to hibernate in the bios. if it's randomly shutting down while you are working then you probably have an overheat issue.
Aug 14, 2009 | E-Machines M5312 Notebook
Computers & Internet Logo
542 people viewed this question
David Payne
David Payne
