Question about Roper REX4634KQ Electric Dryer
Dryer won't start
I was drying a load of laundry and the dryer just stopped working. I changed the thermal fuse and the knob but, nothing has worked. Any suggestions?
  • 2,071 Answers
Dryer does not work at all
Hope this may help;
DON'T FORGET TO RATE:
Posted on Aug 22, 2008
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
How can i change a thermal fuse
remove the two blue wires and the 1/4 screw - replace and reinstall
Nov 01, 2015 | Blomberg DV17542 DV17542 24" Front-Load...
The Dryer is 15 years old . . . whirlpool dryer serial number MD1912702. Last night it was running, drying a load of laundry. It stopped. Now it will not start. the timer works. The power source...
Do not think yet of purchasing new dryer nor calling a service person as this may be a simple problem and you can fix it yourself. You may only need to replace some components as this type of problem is usually caused by a blown thermal fuse which is wired in series with the motor. When it blows, power to the motor is terminated causing the motor not to run. No dryer function works then when the motor cannot run.
The thermal fuse is located on the blower housing along with the cycling thermostat. Disconnect power then access and bypass the thermal fuse. The blower housing is located on the front left bottom of the dryer cabinet for the dryers with lint filter on the front or at the rear left bottom if the lint filter is located on the top of the cabinet.
Dryers with lint filter on the front
Dryers with lint filter on the top
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate the connection properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced including the cycling thermostat if the dryer starts. NEVER use the dryer with the thermal fuse bypassed due to fire hazards. The thermal fuse and the cycling thermostat costs about $35.
Let us know if the problem is not addressed above or if you need further advice but indicate the exact model number of the machine for further advice.
Feb 19, 2011 | Dryers
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer will not start
Check the door switch. It acts as a safety and will not allow the machine to start. The Thermal fuse just keeps the heat form coming on.
Sep 19, 2009 | Dryers
My dryer stopped working. Dryed a load of clothes
Check the door switch. A little lever sticking down through top rightof door opening. If it is not there you will need new doorswitch(sometimes the little lever breaks off). If it is there and doesnot click when you press it in you need a new door switch. if it clicksand clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuseis an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 17, 2009 | Whirlpool Dryers
Dryer wont turn back on.
Hi!! Relax your thermal fuze has shorted out..replace your thermal fuze and all is fine..Good luck..the fuze is located by the motor blower inside the machine its white oval around 2 inches and has 2 wire leads to it good luckk.
Jan 04, 2009 | Kenmore 64992 Electric Dryer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
99 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
