Question about Carrier Heating & Cooling
I HAVE A WALL MOUNTED CARRIER AIR CON UNIT (42QNL012713) WHICH IS SHOWS A FLICKERING GREEN LIGHT WHEN i USE THE REMOTE TO TURN IT ON BUT OTHERWISE DOES NOT SWITCH ON. IS IT SOMETHING OBVIOUS OR DOES IT SOUND AS THJOUGH IT NEEDS SERVICING?
  • 813 Answers
It look like problem in ckt bord u have to go with a professionl service man
Posted on Aug 23, 2008
    Genius:
  • 2,785 Answers
It will be better if you send it for servicing
Why won't my Carrier room A/C stop cooling?
TO MEASURE THE AIR TEMPERATURE AT THE SAME HEIGHT AS YOUR WALL MOUNTED UNIT & COMPARE IT TO THE REMOTE CONTROL SETTING. THERE CAN BE A 8 DEGREE DIFFERENCE BETWEEN THE TWO. I HAVE TO TURN ON MY CEILING FAN TO CIRCULATE THE COLD AIR THAT DROPS AND THE WARM AIR THAT RISES.
GOOD LUCK
Aug 12, 2014 | Carrier Heating & Cooling
I have a Wall mounted Fujitsu Air Con unit (AOT9LSAC) and will only blow room temp air. The green timer light continualy flashes and the red led opperation indicator flashes 8 times. Can you advise me as...
I have exactly the same problem. Pulled apart the outside unit (condenser) and found lizards have crawled under the circuit boards and been cooked. The circuit boards look all burnt and I suspect this is where the damage is. I have removed the boards but not sure where to get replacements.
Nov 13, 2011 | Fujitsu Heating & Cooling
Carrier 42csr series cannot turn on. Only green light at "operations" flashing. what can I do to start it or put it off? the remote doesn't seem to work on it right now.
Transmission problem between remote and PCB sensor. Please replace batteries in your remote and try. If not try with another same type remote. If still problem persists, problem with receiving sensor in PCB. Repair or replace it.
Jan 16, 2011 | Carrier 52PQ307 Wall/Window Air...
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
The unit won't turn on an green light blinks
Reset the error by unplugging the power or turn off the circuit breaker for 10 seconds and power the unit again and operate. If it wont work then you need a qualified technician to correct the error.
Mar 01, 2008 | Carrier 52PQ307 Wall/Window Air...
Heating & Cooling Logo
95 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
