My Sony T.V 2000 model# KV-32XBR400 Is a great T.V we love the size and Pic. the problem is when you turn on the T.V it goes to standby mode and no pic will come on. If you move or shake the large T.V. then try to turn it on then the pic will come up. When the T.V. is hot it will turn off and on just fine! But it seems it's getting harder and harder to turn it on...Also somtimes we can turn it off and on and off and on then it will show a pic...can you help us?
  • 4,234 Answers
There are bad solder connections inside that should easily repaired. If you can solder, you can fix this yourself. Look for solder joints that appear grainy or have rings and resolder them.
Keep us posted.
Dan
Posted on Aug 22, 2008
SOURCE:
The tv wont turn on power button says stand by? model# kv-32xbr400
try pressing Prog + or - buttons. this should wake it if it is not in protection lock down.
Aug 10, 2010 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
KV-32xbr400 switch problem
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. in yor case you have 5 blinks that´s why the last is short to be possible the count..Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
May 18, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Tv turning off
    Hello
    Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
    Regards,
    Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Tv turns off but will turn right back on
    Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
    Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Sony wega kv-32xbr400
    My sony is doing the same thing. but mine blinks 11 times. each time it goes to turn on i hear the clicking then nothing.
    Jun 12, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Sony kv-32xbr400
    Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
    Mar 26, 2006 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Televison & Video Logo
    134 people viewed this question
    Top Televison & Video Experts
    Ekse
