Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA ITC222A CHASSIS
No questions. Just wanted to say thanks for the info on the open fuse for the convergence problems. This thing was driving me crazy! Thanks again..
Retro
  • sons5870 Oct 03, 2008
    When i turn the tv on the green light comes on for 5 seconds then the televiosion makes a fuzzy noise and then shuts itself off . The televion will not turn on at all now.
  • michampagny Oct 22, 2008
    Mine comes on but the edges of the screen are fuzzy and the picture at the bottom of the screen is bent. Where was the fuse you replaced?
    Thanks
    Mike
I have a hitachi 51f500a and the picture is fuzzy and can't eve read enough to adjust
Posted on May 01, 2009
    Genius:
  • 1,030 Answers
Your welcome!
Posted on Oct 04, 2008
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
I cannot find the convergence functions on my tv
Sounds like your talking about an RCA HDTV with the ITC222 or ITC222A chassis. If so the ITC222a Convergence option missing repair kit at the following link will repair that issue. www.tvrepairworld.com
Aug 21, 2009 | Televison & Video
Rca r52wh74yx51 chasis itc222a convergence
These sets do not have convergence ICs it has convergence board most common problem with them is if you go to menu then setup and do not see convergence on menu then you have a open fuse FL231 they are located on right side of FBT flyback transfomer thier is 3 in a roll small brown rectrangler looking caps but are FUSEs it will be the one in the middle.
Aug 14, 2009 | RCA Televison & Video
Convergence problem
Yes, the convergence circuit can fail without blowing any fuses. These Tvs are tough to repair because the convergence output devices are transistors and there will be other small components damaged as well. Get an estimate from a reputable service center before going any further.
michtech
Feb 12, 2009 | RCA R52WH76 Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Rca hd52w59 convergence?
Before you go and buy parts it might be worth your time to check the convergence power supply fuse. It's located in the back of the TV just to the right of a large black component with 2 red wires coming off of the top. This is the flyback transformer. Just to the right of the flyback you should see three fuseable links that look like chicklet's gum. The one that may have fried is the one in the middle, it's a 400mA 125V fuseable link. Hopefully thats all your problem is.
Apr 28, 2008 | RCA HD52W59 HDTV Projection Television
Convergence on a r56wh78 rca projection tv
I located the problem with this set and wanted to pass it on to help anyone with this problem. the chassis # is ITC222A and the problem turned out to be a fuse on the High voltage board. There are 3 fuses that sit next to the flyback transformer and the middle fuse (400 ma 125v) was blown.
Mar 21, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
