Question about Ricoh FAX5510NF Plain Paper Laser
Richo 3310 fax
Error code H548 replaced Triac, and thermistor, what is the reset code for this fax machine? I don't want to reset the numbers that they have stored.
  • skudlock Aug 22, 2008
    I need the reset code, to get into the service mode, to reset this code.
To enter in to service mode press: "clear modes" ,107, "red cl " and hold the red btn for 30 sec
all in that order.
Posted on Oct 10, 2008
System error E000
E000 Fuser thermistor, heater thermal fuse E001 Fuser thermistor, or triac E002 Fuser thermistor, thermal fuse or triac E003 Fuser thermistor, heater, thermal fuse or triac E004 Triac or fuser won't shut off E007 Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407 E010 Main motor drive problem E030 Counter E041 Paper deck motor, clutch or sensor E064 Composite power supply or main motor board E202 Scan problem. Motor sensor E210 Lens drive problem E220 Exposure lamp E240 Main board or composite power supply E260 Main board, power supply cooling fan or composite power supply E261 Composite power supply or fluctuating power E400 ADF communication to machine E401 ADF pickup motor or sensor E402 ADF belt motor drive E403 ADF feed motor or slip sensor E404 ADF exit motor E411 ADF document detect, or registration sensor or edge sensor E500 Sorter communication problem E510 Sorter drive problem E530 Stapler guide b
Jan 06, 2010 | Canon Office Equipment & Supplies
Won't always transmit the fax.
what is the error code? the solution is to find the error code and what it means in the manual.
Oct 22, 2009 | Ricoh FAX3900L Plain Paper Laser
Will not receive fax Will not send fax Will not copy Has error Message 76 on monitor
Machine error 76 is a bad fuser lamp.Sometimes the machines will give a false code and can be reset. Unplug machine. Hold down the Menu key while powering back up. You should still get a Machine error message. Enter the number 9...The display should change to Maintenance 9 then enter 1. The Machine error will return. Enter 99 and then make a test print. If you get either a machine error 76 or 78 you will need to have service done on your machine to have either the lamp or thermistor replaced, and depending on the usage of the machine, it might not be a bad idea to replace the entire fuser.
May 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Richo 3310 fax
What is the model? There are not all the same for the service mode. And what is the reset code for?
Aug 28, 2008 | Ricoh FAX3900L Plain Paper Laser
Machine error 77
the fuser unit (fixing unit) not registering heat requirement. The heat roller or the thermistor sensor is defective.Remove fuser and check roller, if good replace sensor, reinstall fuser and reset machine.
Aug 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Indesit evolution de73 dishwasher
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Apr 07, 2008 | Indesit 24 in. DE73 Evolution...
Machine Error 76
Machine error 76 is a bad fuser lamp. Machine error 78 is a bad thermistor. Machine error 77 means you hade either a Machine error 76 or Machine error 78 and turned the machine off.
Jan 18, 2008 | Brother IntelliFAX 2800 Laser Fax
Ricoh FAX5510NF Plain Paper Laser Logo
213 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
