Question about Hitachi 53FDX01B 53" Rear Projection Television
Sound is distorted
The tv has sound but only if it the volume is all the way up and it is very scratchy. I thought it might be the speakers but when it is hooked up to other speakers it had the same result. Possibly the sound board?
  • 927 Answers
Good Day;
Suspect the audio output IC. If you are using the TV's speakers.
Good Luck, big IRISH.
Posted on Sep 08, 2008
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Sound center
Replace center channel speaker with known good one. If no longer scratchy then the voice coil of removed unit is rubbing against the magnet pole and the speaker needs to be replaced. If the replacement speaker also sounds bad, then the amp for the center channel needs repair.
Nov 23, 2013 | Yamaha RX-V490 Receiver
On low volume using the clean channel the sound is great but as soon as you get to about three or more the sound gets a bit distorted,the amp is the fender hot rod deluxe, ithort i may had blown the...
try a differrent speaker of suitable wattage and ohmage (displayed with a number next to a ? symbol on the back of the speaker),
or
remove the original amp speaker and gently push in and out on it, checking for uneven resistance or scratching. the speaker should retract and return smoothly, without any scratchiness or uneven resistance from within, and if there is any of this scratchiness or uneven resistance from within, the speaker is likely damaged from too much wattage or distortion.
Mar 09, 2011 | Fender Hot Rod Deluxe Guitar Combo...
On my jvc 517v when you turn the volume up the speakers are crackeling and scratchie and speakers sound terrible.
Is this a NEW problem or has it always been like this? What modes or sources are affected? Generally, crackling, scratchty sound is either overdrive distortion, speakers being pushed too hard, or blown speakers.
What is the exact model. Can't find the manual for "517v".
Feb 09, 2010 | JVC Audio Players & Recorders
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
Scratchy sound from cd/dvd combo
sounds like the speakers are either damaged or have gotten water in them and damage the laptop speakers.
Mar 29, 2009 | HP Pavilion Media Center M1090n (PC100A)...
Sound Distortion on Some Channels
you need to fine tune for the distortion channel or else try to auto program
Oct 18, 2008 | Samsung SlimFit TX-S2783 TV
Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Apr 03, 2008 | Yamaha RX-V661 Receiver
Scratchy and Distorted sound
hi, first check the speakers if they r bad, u can do this by connecting external headphones, if it still sounds the same, then the probs is with ur sound card, uninstall it and install it back, let me know
Jan 14, 2008 | HP Compaq Presario V2000 Notebook
No audio
The speakers of the Akai is good so it is tempting to open it louder hence the chance of damaging higher. Try this to find out if your speakers are damaged....... raise the volume if no sounds, 1. remove the cable connection of the speakers from the TV whilst still connected to the speakers. 2.use a 1.5v battery to bridge the free ends of the disconnected cables, if you can hear sound...scratchy sound then the speakers are not damaged then 3. Connect a new external speaker to the TV if still no sounds, post back a message
May 12, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Hitachi 53FDX01B 53" Rear Projection Television Logo
87 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
