Question about Nikon Coolpix 4500 Digital Camera
My camera says the memory card is write protected
  • 1 more comment
  • rhughey1 Dec 28, 2008
    I have a Nikon coolpix L4 and it says it is write protected. I have tried the following but it still does not work.
    - I have made sure the SD card is not locked
    - I have inserted the SD card in my computer and refomatted it but it still does not work.
    - I bought a new SD card and it still does not work.
    Can you help?
    REgards,
    Robert
  • Anonymous Jan 06, 2009
    OMG!!!! I feel dumb!! Thanks!
  • Anonymous Feb 24, 2009
    Mine still says it also, and i keep flipping it on and off to check to see if it works and it keeps doing it.
Just unflip the tiny switch on the memory card!
Posted on Dec 30, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Memory card is protected {reset switch on memory Card} ? Go To review
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 26, 2014 | Kodak EasyShare M530 Digital Camera
Camera shows write protect when open
When what is open? Always keep the battery / memory card door closed. If it is not closed correct, the camera won't work as expected. To protect the file system, when someone should pul out the memory card, while the camera is accessing the memory, it will or shut down completely, or at least protect the memory card against writing to it.
Before opening the battery / memory card cover, always make sure the camera is completely shut off. That means no light is allowed to burn or flicker. The memory card can also be write protected (SD cards) when the lock switch is down like in the picture on the 32GB card.
Before you can make any picture the switch on the card should be up like on the 64GB card on the picture. 3635bcf4-65df-478c-a04d-92e341d15860.jpg
Jan 29, 2014 | Cameras
I have a Kodak Z990 easy share camera and memory card is protected came up and said reset switch on memory card. How do I reset memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 06, 2012 | Kodak Easyshare Max Z990 12mp 30x...
How do i remove the protected card from my camera
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 27, 2010 | Fuji FinePix A201 Digital Camera
It says my memory card is protected
On the side of the memory card, there is a small slider that locks and protects the memory card from being overwritten. Yours may be in the locked position. Simply pull out your memory card form your camera and unlock your memory card by sliding the tab.
Hope this helps,
Andrew
Do not forget to vote.
Apr 09, 2010 | Kodak EasyShare One Digital Camera
Shows the error memory card is protected
When this problem occur you need to set the memory card not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card not protected.
Feb 05, 2010 | Panasonic Lumix DMC-FS7 Digital Camera
Memory card protected
If your memory card is protected, remove the memory card. Look at your memory card you can see there a small push button push it so that the card will not protected. Reinsert your memory card to your camera.
Regards
PCmania
Sep 28, 2009 | Kodak EasyShare C653 Digital Camera
"Memory card is protected"
This error message indicates that the memory card is locked. The switch on the memory card is in the write-protect position. Reset the switch as shown on the camera screen.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Coolpix 4500 Digital Camera Logo
157 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
