Question about Freezers
Digital temperature buttons on upright freezer
I have been given a fairly new upright freezer (whirlpool) I cannot find the model number anywhere apart from these characters "AFG7060". The temperature seem to change every so often and makes a clicking noise and flashes. I have only had this plugged in since yesterday
  • 639 Answers
Hi penshesh,
Happy to help.
This is the model # AFG7060
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
Need mamual model FFU11FKODWO upright Freezer
temperature is set by dial #1 being the warmest and 9 being the coldest the numbers on the dial are only for reference they do not reperesent a certain temperature you will need a thermometer to figure out what number is what temp but they do recommend starting in the middle
Jul 26, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Got zanussi whirpool upright freezer afg8080/1x temperature gone to high is it worth getting repaired or buy a new one? freezer has been making a cliking noise and food is starting to defrost
if the freezer is over 5 years old,buy a new one under counter freezers not built in are fairly inexpensive and will cost less to run.fault sounds like temp sensor....
cheap part/labour intensive.....
Feb 13, 2010 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Unable to adjust temperature with control dial
YOU WILL most likely need a new thermostat for the unit. What evere tripped the breaker apparently welded the contacts on the thermostat. take the model number and the serial number and the thermostat you have here's the part and the model number for you 21 # 216788100 Control-temperature please be sure to rate this soilution after your done. Have a happy new year>
Jan 01, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Whirlpool upright freezer turning itself off
hi,my name is sourine,i have a probrem with my freezer not cool at all,it's about20 year old.
BRAND WHIRLPOOL
model EV150N A O
14.6 c.f
Dec 19, 2008 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
No digital readout
Hello derek143
You Said,
I have a Whirlpool upright freezer AFG 371/H there is a digital display and lights and buttons, on/off temp alarm etc running across the top of the freezer. None of this works but the freezer is still freezing. i have no idea what the temp is.
I think you should try unplugging it for 5 minutes and then try restarting it and see if it reset.
Sep 11, 2008 | Freezers
My freezer is stuck in defrost mode causing the alarm light to remain on
My freezer wouldn't run and I did find there was a reset button on the back of the freezer where the chord runs into the switch.
Jun 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer
if the unit is a auto defrost sound like a defrosting problem, if not a self defrost and the coils are not covered in thick frost then a sealed system issue would be the problem to check
Apr 19, 2008 | Freezers
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
154 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
