Question about Samsung HCM553W 55" Rear Projection Television
Samsung hcm553w problem
I need help getting my screen centered on my tv. the image need to go to the left side of tv about 3 inches and i dont know how to do it.
Tv image is bigger than the screen size.
Posted on Oct 26, 2008
What component should I get to fix my Samsung LCD TV?
HI,
Probably the t con broad is faulty. t con board id the on which drives the LDC panel. I some tvs its not possible to replace the T con board as it would be integrated to the LCD panel normally in 32 inches and bellow. In others i would be separate board which is replaceable individually. I have added a video to know how to locate a t con board which is replaceable individuality. As you didn't mentioned the model number its not possible to add the exact image. In all most all the tvs T con Board (individuality replaceable one ) will be placed on the top center of the tv cover with a metal shield. If its incinerated to the LCD panel then inside the LCD protection metal chassis. Check and fin which one you have.
Samsung LCD TV Repair Identifying Samsung Con Board Part Numbers How to...
www.electro-medical.blogspot.com
Sep 10, 2015 | Samsung Televison & Video
Samsung lcd tv: why is menu bar in the middle of screen?
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size..
Apr 09, 2017 | Samsung LN32B550 32 in. LCD HDTV
I have a samsung HP T5054 plasma tv and today, out of nowhere, a vertical black stripe about 2 inches wide, appeared on the screen. Turning off and restarting does nothing and the scrolling feature to...
There is a possibilty its just a defective address board thats causing the issue. Can yoiu reply to my email address tvtek(at)msn.com with the complete model which will be on the side of the TV. It should be something like HPT5054X/XAA and I also need the serial number. Is the black bar on the left, center or right side of the screen? I need all that information to further assist...
Jun 29, 2010 | Televison & Video
The screen on my tv has two slightly discoloured vertical bars
Sounds like image retention. Is it an older Plasma TV?
Image retention is when an image left is left on for a while actually "burns" into the image. It would be especially noticeable in BluRay because it is a bright image. The burn in was probably cause by watching Cable in 4:3. Try to find a static white image to display over night that should remove the burn in.
Nov 25, 2009 | Samsung Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Apr 20, 2008 | Samsung HCM553W 55" Rear Projection...
Samsung HCM553W 55" Rear Projection Television Logo
56 people viewed this question
Henry  Thomas
Henry Thomas
