Question about Nikon F100 35mm SLR Camera
Nikon F100 dead
Installed fresh batteries, switch ON and nothing happens, nada, zip.
Cleaned the battery contacts - did not help. Is there a simple solution or is it a much more complex problem?
  • jupiter925 Feb 25, 2009
    I have the MB-15 attached to my F100 and recently had a battery leak. I have replaced the battery holder and the camera worked for a week, now it is totally dead. I guess I'll try again to clean the connections or try switching back to the MS-12 to see if that helps.
  • 667 Answers
I do know that on earlier models like the N90s and 8008s, the small nut that holds the battery clip in place activated a cut off switch. If the switch was faulty, the camera would not turn on. There may be a similar switch in the F100.
Posted on Aug 23, 2008
Nikon S6500 will not turn on
Could be the camera, but always first check the contacts from the battery and in the camera. Just to be sure nothing can block a free current. The contacts should be clean and shiny. Not a spec of dust is allowed in the battery holder. If you should need to clean the contacts, only use a dry cloth. Never use a sharp tool in or close to a camera. Then make sure you put in the battery the correct way. I don't know how strong you are, but sometimes people manage to put the battery in the wrong way around. Make sure the battery-camber / Memory card slot cover is closed correct. There is a little switch that indicates if the door is open or closed.
Almost impossible two batteries are dead at the same time. Unless you left them lying for a long time.
When you think everything must be right, just press the power switch several times in a row.
If nothing helps, I guess contact to a Nikon service station, or a new camera?
Jan 30, 2014 | Nikon CoolPix S6500 Red Digital Camera 16...
Camera will not power up
If like most film cameras this one has been sitting for a while unused the batteries are most likely dead AND there might be a considerable amount of corrosion in the battery compartment. All that corrosion needs to be removed before your F100 will work again.
Dec 27, 2010 | Nikon F100 35mm SLR Camera
Battery indicator continues to blink after replacing batteries
Your battery casing contacts may be corroded. Check them for any signs of rust, corrosion, or battery acid. If there are, then gently scrape it off using a small knife or screwdriver other utensil.
Also, are you using re-chargeable batteries? If so, the meter may read low even if they are fresh. The F100 meter has to be reset when it is showing low power by getting enough voltage. So you can try putting in Alkaline or lithium batteries to reset the meter, and then use your rechargeables after it has reset (should be instantly after you turn it on).
The F100 is quite a battery hog and is picky about what is used in it. You may just need to try a different set of batteries to get it to stop showing the low battery.
Oct 15, 2010 | Nikon F100 35mm SLR Camera
Battery symbol keeps flashing and wont stop when fresh ones inserted.
This can happen when the flash has shot at full power and under exposure has occurred. If that does not help call Nikon Film 1-800-645-6687.
Aug 16, 2010 | Nikon F100 35mm SLR Camera
Hi i have Nikon coolpix 5900. Yesterday after
Make sure the battery contacts, both inside the camera and on the battery, is clean. You can clean them with a qtip and alcohol. Also, check the battery voltage, it could be getting old. Here is a good blog of things to check with this problem:
Good luck, and hope this helps.
Jul 04, 2010 | Nikon Coolpix L11 Digital Camera
Nikon F100 suddenly went dead
Which battery holder are you using? The small one or the grip MB-15? If it is the MB-15 make sure it is screwed in tight. If it is the small one then make sure your batteries are in the correct direction. If that does not work call Nikon Film 1-800-645-6687.
May 16, 2010 | Nikon F100 35mm SLR Camera
The camera won't turn on.
With these batteries not working in two cameras I would check the batteries with a battery tester. One could be low and it does not take much below two-thirds to cause a camera not to operate. Also, in the camera with the acid that acid can creep into the internals of the camera where you and I cannot get to. It would be best to send it to Nikon for a CLS. You may call Nikon Film 1-800-645-6687 as well.
Mar 27, 2010 | Nikon F100 35mm SLR Camera
Inoperative Nikon 4F
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jan 20, 2010 | Nikon F4s 35mm SLR Camera
My P5100 will not turn on - no green light & lens is stuck in ''out'' position
If nothing happens with a fresh battery set, then nothing can be done. Some thing has to happen in order to be able to tell what is going on.
If there indeed nothing happening when a fresh battery set is in and the on button is pressed, that means the camera needs service or some serious repair. This could be something very simple inside such as a disconnected or loose cable. On the other hand, this can also mean that this camera is good for selling on a site such as Ebay as parts or a fixer.
There is a Nikon P5100. If it is a Nikon, then you may consider this link to call the Nikon co. and ask for either repair or a trade-off or trade up to a similar camera or better. Nikon does have a trade-in or trade-up program.
Aug 31, 2009 | Cameras
Nothing happens when I turn the camera on.
First would be to check your batteries. If they are good look inside the battery holder see if there is battery corrosion, if so it should go to Nikon for CLA.
Call Nikon Nikon Film 1-800-645-6687
Feb 18, 2009 | Nikon F100 with 28-80 and 70-300 lens 35mm...
Nikon F100 35mm SLR Camera Logo
263 people viewed this question
Top Nikon Photography Experts
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
