Question about Dirt Devil Vacuums
I have a dirt devil (ultra vision) it will not pick up anything i dont know what is wrong. It will not pick up dirt through the pipes no pressure in the pipes
  • 706 Answers
Will try to help here.. first off.. regardless of the brand..upright vacs operate pretty much the same way.. I assume that when you plug it in and start it that the motor runs as well as the beater brush on the base.. from the sound of your symptoms and presuming everything runs.. you probably have a clogged line between the base and the motor.. If you unplug it first then flip it over so you can see the base bottom.look for recessed screws in the plastic bottom cover and back them out ( you will reuse them later so do not lose them) Once you get all the screws out..you should be able to remove the wheels and bottom cover.. You'll probably see a fair amount of debris there so you may want to do all this over a barrel... Next, with the bottom cover removed... you should see a path or hose that will channel all the dirt etc up to the bag or bucket...That is probably blocked up and you may need another vac and/or metal coat hanger cut open and formed into a pick to pry some of that material out of the line.. If you have access to another vacuum ..try using that to free up any lodged material in the tubing.. Hope that helps...
Posted on Aug 22, 2008
Dust Devil UD40180 repair manuel
Mate I just googled Dust Devil UD40180 repair manual and found this link, I hope it helps... If not then you google Dust Devil UD40180 repair manual It might give you some ideas...CHEERS
http://www.ereplacementparts.com/dirt-devil-ud40180-ultra-vision-turbo-bagless-upright-vacuum-parts-c-36976_37103_37186.html
Mar 12, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
My dirt devil ultra vision won't pick up anything and the brush does not turn, also smells like rubber is burning. What should I do? I checked to see if it was clogged and the belt is not broken.
Sounds to me like the belt has gone or at least stretched so it is slipping on the spindle, take the brush out and check for hair or anything wound round where the belt grips...don't know this particular vac but usually belts are not too difficult to change. Get a new belt from your hardware shop
Jul 11, 2011 | Vacuums
Have ultra vision and have changed filter and foam filter, checked all hoses but still will not pick up. Belt is fine and brush is clean and spinning properly. dirt stays at top of filter instead of...
My kids get mine stuck all the time :(
Take the vacuum outside then:
Remove the hose at the bottom and see if there is any obstructions. Also shake the hose to make sure there is nothing in there as well or take it out side and make sure you can see light through it.
Let me know if this has helped or if I can help you with anything else,
Thanks
Mar 31, 2011 | Dirt Devil Vacuums
Vacuum won't pick up
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
May 28, 2010 | Dirt Devil Vision Turbo W/Bonus Upright...
My Dirt Devil ultra vision will not **** from base
Your belt is probably worn or broken. You need to replace the belt if you haven't recently. You can get the belts you need here:
Dirt Devil Ultra Vision Replacement Belts
Nov 07, 2009 | Vacuums
No Wind Coming Out of Dirt Devil
The suction hole will never have wind coming out of it, it is for suction. To switch from floor to hose, turn the control knob labeled floor / hose.
May 02, 2009 | Dirt Devil Vacuums
I don't know how to change the belt on the dirt devil ultra vision no manual
Take all the screws off the bottom to access the beater bar than slide out (belt will also be right there ) just slide a new one on......
Jan 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt Devil Vision bagless not working
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Jan 24, 2009 | Dirt Devil Featherlight Bagless Upright...
Is there a reacll for the dirt devil ultra vision turbo bagless vacuum?
Go to the store and read the recall announcement.
Aug 25, 2017 | Vacuums
Vacuums Logo
180 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
