Question about Kitchen Ranges
Our cooktop will not turn on!!
The lockout control on our 5 year old cooktop has us locked out and we cannot get the electronics to let us unlock the cooktop. What must we do now? I have a Frigidaire electric slide in range, model # plefz398ec, and after self cleaning it, although i was able to open the oven door - however, the cooktop remains locked. It shows the little red padlock icon and the lockout feature ( - - ) is displayed in the digital window above the knob.
I called frigidaire tech support and over the phone they said, I should push the clock button for 3 sec. What this did, changed only the clock display from the time to 12hr display. I turned the braker off, nothing happened.
Any input would help.
Oh, by the way, the oven and warming drawer works, the problem lies only with the cooktop part.
  • rachaelleigh Mar 11, 2009
    My Frigidaire cooktop locked up on its own. I can use the oven but none of the burners but the oven and the warming drawer works. There is a little red padlock on my display and two green dashes above each burners digital display. I pressed the lock button for 3 seconds but it will not unlock the stovetop. My model no. is PLEFMZ99BEK
  • robert samples May 11, 2010
    try holding the clear off button for 5 secs or till the lock light goes off
Hold down the OVEN LIGHT button for 30 secs. I'll never forget this. It cost me $96.50 to find out.
Posted on Apr 09, 2013
  • 5 Answers
Got the same problem.
Here's a work around: Turn breaker off, second person needs to hold the CANCLE/LOCK button (keep holding it!)
Turn breaker back on and keep holding the button, lock feature may turn on, red lock light stays on, KEEP HOLDING THE BUTTON. At the end you will get a F11 (shorted keypad) warning. It may take up to 20 seconds or more but in my case the red lock light goes off, the dashes disappear and everything is back to normal.
Now here are the bad news. This does not fix the problem (I think it's the EOC). Every time the power goes off the red lock light and dashes will come back. It also may require to people to fix this/work around... but, hey, it doesn't cost anything either...
Posted on Dec 10, 2009
  • frankegd
    frankegd Jan 26, 2010
    Well, after further investigation I found out that simply holding the "Oven light" button for some time will unlock (red padlock) the cooktop...
Error 40 on kenmore convection oven
The 40 error code indicates a failure of the cooktop lockout board. The cooktop lockout board is not communicating with the main EOC electronic oven control. This could be a loose wiring harness or either the EOC board or cooktop lockout board is faulty. This type of diagnosis will require using a volt/ohm meter. If you decide to check the harness to the boards you will need to remove the back panel for access.
Oct 15, 2017 | Kenmore Ovens
I cannot unlock the cooktop on my Kenmore gas range. There is no lockout button, only Select Clean and Stop/Clear. Neither one of which unlocked the cooktop. There is a little padlock looking symbol t
I'm sorry, but the model number given in the question is either wrong or incomplete. Please check that model number. Usually, on Kenmore ranges, you can find the model # and serial # on either the left or right side of the storage or warmer drawer. Open the drawer and look on the frame of the range for a label. On a few ranges, the label is affixed to the frame between the oven door and the drawer.
As an alternative, please post a clear picture of the control panel.
Oct 20, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
How do I fix an F40 code on a kenmore elite rlectric range model #790.46709603
The "F40" fault code indicates a Cooktop Lockout error. There is a "Lockout" control board that locks out the cooktop from operating whenever the "Clean" cycle is used. It's not normal to display "F40" unless there is a "Lockout" or an "EOC" (electronic oven control) failure. It may need one or the other or both boards replaced. If the cooktop will operate after the range has cooled and unlocked then it may need the EOC and not the Lockout board. If you can ignore the beeping and the F40 and the range will heat up again in the clean cycle and complete the clean cycle then it could have a faulty Lockout board. Here a link to a YouTube video with the instructions on how to access and replace the EOC.
Here is the lockout board if you need to order it.
Here is the EOC board if you should need it also.
All parts come with a 365 day, any part, any reason return policy.
Apr 06, 2013 | Kitchen Ranges
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
Hello, i cannot turn the child lock off on my stovetop. this is a brand new problem as i do know how to normally turn the lock off.
Not sure if this is for your exact model but here is a link to an Online User's Manual for one similar:
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KECC508RPS_Use%20and%20Care_EN.pdf
Just click on the link (underlined and highlighted text) with your mouse and a new browser window will automatically open to show you the information in the manual.
On page 7, it reads as follows:
To Lock Cooktop: Touch and hold the CONTROL LOCK/
ALL OFF keypad for 5 seconds. After 5 seconds, CONTROL
LOCK will glow red, indicating that the cooktop touch controls
To Unlock Cooktop: Touch and hold the CONTROL LOCK/
If you have any questions or require further assistance just comment back to this page and I will endeavour to help.
Good luck and please click on the 4 Thumbs Up rating icon if this was at all helpful.
Thank you very much.
Joe.
Feb 17, 2011 | KitchenAid Cooktops
The burners won't work but the oven does! please help me. i was in the middle of cooking and all of the sudden it stopped working. i checked the circuit breaker box and nothing was blown. thanks! Lori
you have the cooktop lockout engaged, this may be a control failure, but try to turn off the cooktop lockout first by pressing and holding the control button with a pic of a lock by it. if this doesn't work, replace the control board.
Jul 02, 2009 | GE Spectra JBP78 Electric Kitchen Range
Stove top will not turn on - touch control
I have a Kenmore and it did that. I kept the lockout button pushed in until it beeped
May 31, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
Need to unlock the controls of my Whirlpool gas oven
To Lock Or Unlock Cooktop
1. Turn all control knobs to OFF.
2. Press and hold the Cooktop Lockout icon keypad for 3 seconds. A single tone will
sound, and “Loc On” and a cooktop icon will appear on the display. After 3 sec-
onds the clock display will reappear.
3. Repeat steps 1 and 2 to unlock cooktop. “Loc OFF” will appear on the display for
3 seconds, and the cooktop icon will disappear from the display.
Feb 13, 2008 | Whirlpool SF367 Gas Kitchen Range
Plug the power line press the reset button.
Jan 03, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
Kitchen Ranges Logo
651 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
