Question about JVC BR-DV3000U DV/Mini DV VCR
JVC BR-DV3000 Mini DV-DVCAM issue
When I insert a mini dv tape into the 3000, it plays it like it is a dvcam tape. This just started out of the blue. It only seems to do it with the mini dv tape...not the standared dv tape. Any Clue?
Ron
  • PaulD2255 Oct 30, 2008
    When playing the mini dv (SP) tape, in the BR-DV3000U, tape speed will search between SP & Cam making the output usless.
  • IgorR Nov 14, 2008
    That problem comes only when reading a MiniDv tape (didn't try with a Dv) but when recording, there is no problem
  • 320 Answers
If the problem only shows with Mini DV tapes, it can be a tape guide issue or a mchanism loading problem where the tape is not being properly "seated" into the tape mechanism. You will need to use an oscilloscope to look at the RF waveform coming off the tape to try and figure out where your problem is.
Posted on Nov 08, 2008
I HAVE A PROBLEM TO RECORD A DVD TO DVCAM MINI DV, JVC - BR-DV3000
If it is a commercial Dvd it probably has copy protection.
Dec 30, 2014 | JVC Video Cameras
JVC BR-DV3000 Mini DV-DVCAM driver
Try JVC first but what do you expect to find a driver for?
Jun 13, 2012 | JVC BR-DV3000U DV/Mini DV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
With MiniDV tapes, the DVCam indicator ignites and the reading becomes jerked.
It could be several things causing your problem. The video head may be worn, the tape guides may be out of alignment or you may have a mechanism problem keeping the tape from wrapping securely around the rotating drum. If you can use an oscilloscope, you should check the RF signal coming off the drum test point to see if it is clean, or if half the signal is missing (bad drum or video head) or not smooth (guides out of adjustment).
Nov 08, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Fire connection
Do you have its Service Manaul to check any hardware problem in unit?
Aug 03, 2008 | Sony DSR-1500 Mini DV VCR
Tapes not in 24p play for 2 seconds than stop, WHY?
The BR-DV3000 DV deck has LP inhibit function which is set in the operations menu. JVC does not recommend the use of LP mode and therefore locks this mode out by default. You can change this setting to allow operation in LP mode if you like but I don't recommend it. Using LP mode on DV tape causes the error rate to escalate due to the narrower track width produced by the slow moving tape. Good Luck, this is a nice machine! Joe Weibel Custom Electronics (customelectronics.org)
Feb 13, 2007 | JVC BR-DV3000U DV/Mini DV VCR
Won't play DVCAM, will play Mini DV
it is probably matter of dirty guide so the timecode stop reading try a wet head cleaning tape to play it there regards please don't forget to rate ,thx
Feb 20, 2007 | Sony DSR-45P DV / Mini DV VCR
JVC BR-DV3000U DV/Mini DV VCR Logo
685 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
