Question about Fuji FinePix 2300 Digital Camera
My Fujifilm digital camera is connected to my computer, but the removable disk does not appear when I open "My Computer" in Windows. I have a FinePix camera and have installed the software.
    Master:
  • 425 Answers
If the removable disk does not appear when you open "My Computer" in Windows, it is possible that the USB drivers are not installed correctly. Update to the latest version of FinePix Viewer (including the USB drivers). To update FinePix Viewer, you must have the software from the CD-ROM bundled with the product (Utilities for FinePix) already installed. As an alternative method to updating the software, you can also reinstall the USB drivers. The USB drivers can be reinstalled by installing the software from the CD-ROM again. If the removable disk is still not displayed after the above measures have been taken, check the following: Windows system checks 1. You should be using Windows 98, Windows 98SE, Windows ME, Windows 2000 or Windows XP. 2. The Windows XP USB drivers are supported as standard system drivers but are only compatible with Software for FinePix versions 2.0 or later. If you are using an earlier version of the CD-ROM, an update to FinePix Viewer is required. 3. The software cannot be installed properly from "Scanners and Cameras" in the Control Panel. Digital camera checks 1. Check that the digital camera can play back images on its LCD monitor. 2. On digital cameras with the PC Camera function, select "DSC" as the USB setting. (Refer to the Owner's Manual for your camera for information on specifying the camera settings.)
Posted on Aug 30, 2005
SOURCE:
Why won't the driver for my fujifilm finepix AX300 install on windows vista?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Oct 21, 2012 | FUJIFILM FinePix AX300 / AX305 Digital...
Hello, We've just bought a FInePix XP10 and can't get the camera to connect to our computer or TV using the supplied USB cable. Camera screen reads 'USB' which suggests something's happening but nothing...
The camera's memory will appear as a disk drive in "My Computer" (Windows). You will find your images as files in a directory on that drive. I don't know about connecting to a TV- presumably it has a USB socket, so I imagine that it will access the camera as a disk drive as well. You will need to read your TV manual to discover how that works. Possibly you press the play button to get a menu onscreen, or the USB button if there is one.
Oct 19, 2010 | FUJIFILM FinePix XP10 XP11 Digital Camera
Can I upload my photos from a JV100 fujifilm camera to a windows 98 computer?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 25, 2010 | FUJIFILM FinePix JV100 Digital Camera
I have fujifilm finepix s9600 and need the software to download photos. Can i download this from the net
when you connect your camera with the pc the camera will probably appear as a seperate drive on your computer. for example if you have a hard disk C: and a dvd driver named D: check to see if a new external disk appears as E: which will contain the folder of your pictures on your camera.
you can also check here
http://www.fujifilm.com/products/digital_cameras/s/finepix_s9600/index.html
Jan 23, 2010 | Fuji Finepix S9600 Digital Camera
How can i put pictures from the camera to my computer
Download the manual from http://www.myacrobatpdf.com/7730/fujifilm-finepix-s5700-finepix-s700-manual.html for detailed instructions. Otherwise, connect a USB cable to the camera and to your PC. Switch the camera on and wait for the computer to recognise it. It should appear as another disk drive under "My Computer" Double click on the drive and it will open the folder structure. You can now right click and "copy" the photos from the camera to the computer folder you wish to put them in
Aug 16, 2009 | Fuji FinePix S700 Digital Camera
Aug 30, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 1300 Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Fuji FinePix 2300 Digital Camera Logo
169 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
