Question about Dishwashers
Ge nautilus dishwasher--leaking when running
Found problem -- rubber coupling joining pump to bottom of unit had a small split in it .replaced coupler problem solved. Thanks for pointing me in right direction. hamms4
    Scholar:
  • 132 Answers
Hamms4
Wonderful - Hope you've got some satisfaction from repairing and resolving the problem
Kind Regards
TC
Posted on Aug 23, 2008
SOURCE:
Water in bottom of GE Nautilus dishwasher
I was having the same problem and downloaded a copy of the manual and found out it is normal for a couple of inches to remain in the tub! I can't remember where I downloaded the manual, but you can "Google" it like I did. Hope this helps :o)
May 15, 2009 | GE Nautilus 24" Built-in Dishwasher
How to change a GE dishwasher door seal
I had the same exact problem TWICE....second time I'm replacing the dishwasher. There are two rubber boots at the bottom of the door that just sit and the door seal is supposed to seat into these rubber boots but if you take out the boot you will see that it is misshapen and therefore leaking. These boots cost about $10 dollars apiece from GE on line. I replaced them once and same problem. I was going to replace the gasket that runs around the door but it costs $50 and I'm not SURE it will fix the problem. I'm on my way right now to buy a new dishwasher....they're not that expensive compared to pumping money into something that you don't know if it will work. Good Luck.
Nov 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaks while running
The water at the bottom is normal if you open it during the cycle. Leak means you need to replace the L-shaped black, molded gasket that is in the lower left or right of your door opening. Replacement is easy - requires no tools. Part can be purchased for about $10 each at Sears parts department.
Sep 07, 2008 | GE Nautilus 24" Built-in Dishwasher
Motor
The only reasons to replace a pump motor are very loud motor or leaking water from the seal of the pump / motor assembly. The motor comes as the pump / motor assembly, and is not real cheap and not particularly easy to replace, so you may want to consider cost of replacing the entire unit. Appliance repair locations can order for you, or you can order directly from GE over the phone. (GE answer center 800-626-2000) Make sure you have complete model number, located on the sticker on the left side of the tub just inside the door.
Sep 01, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
