Question about EliteGroup L7VMM2 Motherboard
No video monitor black
Changed mother board and still no video monitor black
  • esginme207 Aug 24, 2008
    hoe do i update mother board with no vedio cant see nothing
    yes i have another computer to test them both
  • 3,051 Answers
Have u checked out the video card and monitor and make sure it is all in good working order
Posted on Aug 24, 2008
Come on screen but at that time when I press the menu all menu function come on screen but pc display not come. I change display cable & video board also but problem not solve.So, Pls. guide me. Thanks.
If again again display problem create then i suggest you change mother board and purchase own device supported mother board. If change mother board then display problem solved, but one step you change RAM may be your RAM device week and damage. So you first of all change RAM then finally change motherboard.
Thanks...
Oct 09, 2013 | LG 700M 17" CRT Monitor
No input signal message and screen goes black
Check your video cable going from your monitor to the pc. If your trying to use more than 1 monitor, is your video card capable of using more than 1? Are you using the mother board video card or a store bought one?
Jul 22, 2012 | HP W2338H 23-Inch Widescreen Monitor
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
My laptop turns on, but there's nothing on the screen.It's black.
It will either be your motherboard or LCD. The first thing you want to do it hookup an external monitor to your laptop and then power it on. If you get normal video on your external monitor then it is an issue with your LCD that can either be the cable that connects the LCD to the mother board or the LCD itself.
If you get no video at all on the laptop or the 2nd monitor then it is a problem with your motherboard and you will need to have that replaced. Be sure to test for video on the 2nd monitor with the laptop closed and then opened. Also, make sure you press the function keys on the keyboard to switch displays. It would be no fun to think the mother board was bad when it was really the LCD and you just forgot to enable the external port :)
Aug 21, 2009 | Acer Aspire One PC Notebook
Dell Monitor Not Working
well if the status of the LEd on the monitor is amber(orange) & the system is running on a on board video card & not a Add-on video card... it is a possibility the the integrated video card ot the mother board might have gone bad... either contact a local tech or the tech support for the computer...
also unplug the monitor cable from the system tower & then if you see that there are the bars moving which say monitor self test on... means tht the problem is with the video card or the mother board...
since the system is running on a integrated video card...
Jan 17, 2009 | Dell 828FI 15" CRT Monitor
I cant get my monitor to work with this mother board
first be sure that the monitor is working (plug into another computer or laptop).
on you have that try to get a video card, it might solve you problem, if not change the mother board
have a good christmas
Dec 24, 2008 | Computers & Internet
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
Computer turns on, but there is no display on monitor.
my goodness.. you have spent a lot in your computer i think.. i dont think changing mother board and installing a new vedio card will solve this problem.
as u have said that u have installed a new card make sure that you are giving the connections of your monitor to the gforce card and not to the mother board again.
if connection for monitor is going for gforce properly your RAM is the problem. as per your configuration its single 512mb ram. i would advice you to go and get another DDR RAM(same 512 prefrably) from any of your friend and put it in you mother board in by removing the normal RAM you had.
this will work for sure i think.
if this is not working dont rate me in-approtiate. i just triend my best. sorry and tahnks.. good luck
Dec 28, 2007 | Computers & Internet
Monitor resolution can't be changed
some 15" monitors do not support 1024 by 768, check your monitor specifications if it does. google on the net with the exact monitor model no. and see if it supports.
Sep 28, 2007 | LG Flatron 995FT 19" CRT Monitor
Mother board
It's a possible motherboard issue. Had same issue and troubleshot to the MB. Everything else checked out fine. PC was working fine up till then.
Sep 13, 2007 | HP Pavilion a1240n (EG136AA) PC Desktop
EliteGroup L7VMM2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
