Question about Lexmark Office Equipment & Supplies
Cannot get my printer to respond..when I trouble shoot it says printing paused, I click on resume printing and it still doesn't print... I unplug my printer and turn off my computer and once I restart my computer, my printer will print the jobs it wouldn't print....help!
    Novelist:
  • 110 Answers
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Posted on Aug 22, 2008
Printer is on pause
On your computer, go to Start menu > Printers & Faxes > double-click on the Lexmark X2600 Series print object. In the print queue window, click on Printer tab and select Resume Printing. Try to print again to verify that the problem is fixed.
If that doesn't help, try the steps below:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Oct 03, 2011 | Lexmark X2670 All-In-One Printer
Won't print...says printer is on pause
According to your problem, first check the printer settings. Go to the Printer and faxes wizard in control panel. Right click on printer, if you fond there Resume printing then click on it. It will make printer working. Then reboot the printer and the system both. If it doesn't help you then there is the problem of printer software. Reinstall printer driver/ software again and reboot the both.
Jun 21, 2011 | HP Officejet 6500 Wireless All-in-One...
My dell p703w printer is not printing black even though i cleaned printer head and reset setting tried several new cartridges what do i do now
Printer Problems Ensure that the printer power cable is firmly connected to the printer and the electrical outlet.
Determine if the printer has been held or paused.
  1. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows Vista®:
  1. Click windoa14.jpg ® Control Panel.
  2. Click Hardware and Sound.
  3. Click Printers.
  1. Right-click the printer icon.
  2. Ensure that Pause Printing is not selected. If Pause Printing is selected, click Resume Printing.
Ensure that you installed the ink cartridges correctly and removed the orange caps from each cartridge.
For more information, see Replacing Ink Cartridges.
Ensure that you loaded the paper correctly.
For more information, see Loading Paper.
Ensure that the printer is not connected to a PictBridge-enabled camera.
For more information, see Printing Photos From a PictBridge-Enabled Camera.
for more detail see this page
http://support.dell.com/support/edocs/systems/p703w/en/UG/troubles.htm
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Dell P703w Printer
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
Was printing fine but now when I send something to print, the printer doesn't respond at all and just shows the "ready" screen
Is it connected directly to your PC, or is it networked?
In your printer dialog box, does the printer say "ready"? it may be "Paused" or "offline". Right click and select "resume Printing", and/or "use printer online"
Are you sure the cable is still connected and working?
try removing and reinstalling driver.
Mar 11, 2009 | HP LaserJet 3600n Printer
Pausing printer
Try enlarging your "Printer Buffer" if you can.. OR maybe you need to set your Parallel Port to a differsnt mode in the BIOS. And/Or try updating your "Drivers" see if this all helps.
Jun 18, 2007 | Epson LQ-570e Matrix Printer
Cannot resume printing
try these two solutions, open the print controller on the menu and click on re-start, or power off the printer and do a test page through the computer to see if it is responding.
Apr 23, 2007 | Epson Stylus C66 Inkjet Printer
108 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
