Acer 6920. no hdmi output. error code 0122 - Computers & Internet
  • Anonymous Sep 13, 2008
    i have the same problem as above aswell.
The Acer 6920 cannot show a movie on both screens at the same time. You must choose one or the other (the TV or the Laptop screen) NOT both.
Posted on Sep 14, 2008
SOURCE:
Where do i buy the hdmi card or device for a acer aspre 6920
There is not an HDMI card or device for use with this model.
Jun 02, 2010 | Acer Aspire 6920 Notebook PC
I bought the Acer 6920 factory restore CD's to set it back to factory default but when i run it it gets to the third disk at 90% and then says Restore Failed and gives me this Error code 0xd000000a. Does...
It stands to reason that if it ran the other 2 it should run all of them. that tells me its probably not your system. The disk could be faulty. I would check with manufactuer.
Apr 05, 2010 | Acer Aspire 6920 Notebook PC
Connecting an Acer 6920G to a LCD TV
Unfortunately, DVI doesn't support audio. Your headphone output may work if you have a PC audio input on the TV. However, you might need to change the audio output on the Acer 6290G. It is probably defaulting to using the HDMI audio output.
Go to the Control Panel (click on Start). Select the Hardware and Sounds section. In Sounds, look for Manage Audio Devices. Change the Default Audio Device to a different Audio device (look for Output in the description). Note: you may need to turn off the computer and TV and turn them both on for the headphone jack cable to be identified.
If this doesn't work, check the manual for the TV. It might only have the PC audio connection available for a VGA port. Please add a comment with the TV model, if you need assistance with this step. Make sure that you aren't connecting the headphone out of the 6920G to a headphone out on the TV.
I hope this helps.
Sep 07, 2017 | Acer Aspire 6920-6422 Notebook
Acer aspire 6920 hdmi port
Just do 1 thing press in and leave the tray/ small botton. if done thumbs me.
Nov 12, 2009 | Acer Aspire 6920 Notebook PC
Connect my 6920 to tv or through foxtel
Hi the 6920 may have a HDMI out(mine does) if not Maplin are selling a PC to TV box, it converts VGA to AV signal (£30) hope this helps
Feb 21, 2009 | Acer Aspire 6920 Notebook PC
Cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Jan 19, 2009 | Acer Aspire 6920 Notebook PC
Acer 6920 hdmi sound output
An HDMI cable carries audio and video. Connect the HDMI cable to the cable box and to the tv. Make sure you then select the HDMI input on your TV. Also, make sure the internal audio is turned on in the Samsung TV settings. If all is setup correctly and you still have no audio try using a different HDMI cable.
Nov 29, 2008 | Computers & Internet
Incompatable graphic driver error message 0122
hi I too got the same issue, on my 6920, acer recomendet to re formate the hard driv to is original . But I thing it should be isier to fix it , rather to reformate how can I quiker fix
Aug 23, 2008 | Computers & Internet
Error code 0122 when trying to play blue ray disk on hdtv through hdmi cable
Hy guys
I had this problem earlier on today and after much searching found a solution that worked for me.
This error message relates to piracy issues. If you are running 2 screens at once (laptop monitor and HD TV) I guess it's seen as an easy way to pirate DVD's, Blu-rays etc.
Go into your graphics card settings (i think I did this in the end by adusting screen resolution (was hungover, there's probably a quicker way - this gave me access to my ATI graphics card settings). you should be given an option of taking your HD TV as the primary monitor and disabling the built in monitor.
This should resolve the conflict that caused the 0122 error message - there are no longer 2 monitors, I guess making it harder for the pirates to comoplete their dastardly deeds - aaaarrrr.
I hope this helps some peeps out - thought I'd return the favour for my own various questions.
StrangePlanet
Jul 12, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
129 people viewed this question
Ekse
Alun Cox
