Question about Hotpoint Washing Machines
My hopoint bwd 129 drum is not turning. Could it be a problem with belt. I so how do a replace the belt?
  • 985 Answers
There is an access hatch on the back of the washer.
Do some basic troubleshooting first:
  1. Open the door and spin the drum by hand. Does it move OK? i.e. it isn't jammed.
  2. Does it spin really really well like there is no resistance at all? Possible snapped belt.
Pull the washer out carefully and make sure there's enough slack on the water hoses and mains cable to get access to the back without causing a problem. Look at the back panel, there's a large oval panel approx 16" tall by 12" wide. It is held on by five or six screws. Using a cross head screwdriver of the correct size remove these screws. Grab the bottom edge of the panel and tilt it up slightly to slide it out.
You'll be looking at the back of the washer drum. The motor is at the bottom slightly before 6 o'clock. It should be obvious if the belt is attached or not.
Replacing the belt is straightforward. Just make sure it lines up with the grooves on the motor pulley.
Posted on Sep 13, 2008
SOURCE:
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 25, 2012 | Washing Machines
Hotpoint bwd 129 leaking from underneath (left side when looking at the machine) - i have checked the plugs at the back - all okay.
Hotpoint bwd 129 leaking from underneath This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 08, 2010 | Washing Machines
Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Feb 12, 2010 | Washing Machines
PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD 129-ON DRY CYCLE CLOTHES COME OUT STEAMING AND WET. PLEASE ADVISE
If the clothes are coming out hot and steaming, then the water from the clothes is not condensing, it could be a blocked condenser, which will have to be removed and unblocked and cleaned.
The other possibility is that there is no cold water coming in on the drying cycle, this can also have the same effect.
Hope this helps.
Dec 03, 2009 | Hotpoint Washing Machines
Is Hotpoint washer/dryer bwd 129 cold fill only
From what I could find online at the Hotpoint UK website (this is probably very similar to the US site) it is a coldfill machine. This product brochure has a similar machine listed on page 25 (13 of 19). Hope this is helpful to you
Sep 02, 2009 | Washing Machines
I have a Hotpoint BWD 129 and it's stuck on the wash cycle.
Hi this is abhishek welcome to fixya
its actually a timer problem,,,,,,better to fix it
thank u....
May 03, 2009 | Washing Machines
Hotpoint BWD 129
Hi, full manual is here, you have to register but it seems legit, very useful site, hope it helps.
http://dl.owneriq.net/b/ba32d489-448f-4923-9f5f-26806e5b290c.pdf
May 29, 2008 | Hotpoint WD52 Front Load Washer / Dryer
Washing Machines Logo
41 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
