Question about Panasonic DMR-E20 DVD Recorder
Doesn't read disks
I can load a fresh DVD-R or a commercially produced movie and all I get is U11 error-disk is dirty or scratched. My disks are pristine.
  • llebsi2 Aug 24, 2008
    llebsi2
    I followed BobbyR1234's instructions to theletter and the unit still comes up with error code : U11 which the manual says is a dirty or scratched disk.I even bought a new movie and opened it for the first time to test the machine and still no luck. I am aware of the fact that I must use DVD-Ram,DVD-R or commercially produced movies in this machine so I'm not trying to load improper media.
    What about the possibility of a drive failureor I noticed 2 3volt batteries soldered to the motherboard-if one or both fails could this cause my problem?
    President:
  • 173 Answers
If you are getting the error that states your discs are dirty then the problem could be that your optical lens is dirty. You will need to open the tray then unplug the unit from the wall. Get some cotton cu tips and rubbing alcohol. If you look inside the laser carriage you will see a glass looking bubble in the middle (that is your optical lens). Dip a cu tip lightly into the rubbing alcohol making sure you do not totally saturate it. Gently clean the optical lens in a circular fashion with the cu tip. Repeat this step a few times and then let air dry for 2 minutes before plugging the device back in and then replace the cover and try playing your discs. For best results clean your optical lens once every two months (sooner if you live in a dry dusty climate or have pets inside along with blowing out the inside with a can of compressed air) also clean your discs often to keep them in good shape and place them in their cases when not in use to avoid scratches. You can check out my tips for cleaning dvd/cd discs for more information also. Let me know if you need further assistance.
If you would not mind please rate my help, I would greatly appreciate it. Thanks
Posted on Aug 23, 2008
SOURCE:
My Honda Odyssey 2007 dvd player wont play. The player keeps saying loading then it will either eject the dvd or read error. The battery never died and I've tried different dvds, none of them work.
its probably dead.
a tech, ,opens the drive and cleans it , in the hope it come back.
looking for , junk (labels) in the drive. broken disks , parts inside
or dust on optics, cars are dust magnets, so.......
if it's not something easy, most replace it. it's cheaper that real repairs.
but all can be fixed in any pro electronics shop and all parts can be had. parts + labor can hit $200 easy or more,
id up grade to USB memory stick Headend radio
and use them, an never DVD again, they really are obsolete now.
really. id move up.. 1000s of songs on one stick, no more scratched skipping or dirty disk.s
DVD is dead, (first run movies excepted, but VOD is killing this)
Oct 02, 2013 | Honda Odyssey Cars & Trucks
Dvd reading error
Try using a known-good (for instance, a movie you just watched on your TV). If it doesn't read that disc, make certain you have seated the disk in the drive properly (Laptop drives have a *CLICK!* when you have seated the disc properly). If that doesn't work- if the laptop is in warranty, get it fixed. If not, use an external drive to fulfill your media needs
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Sep 22, 2012 | HP Pavilion dv6775us Notebook
A disk read error occurred
Was this read error on the hard drive, or on a disk installed in the CD/DVD player? If it was a hard drive, then running Checkdisk on the drive will detect and isolate any failed areas. If too many failures occur, you may want to consider a new drive before total failure (and loss of data) occurs. If it was a CD/DVD read error, then the disk may e dirty or scratched. The drive may require cleaning. Or, if the disk was burned on a PC and not commercially, the media may not be fully compatible with the drive in your machine. Some media don't work well with some brands of drives. Almost all manufacturers websites list recommended media for their drives.
Jan 12, 2012 | Gateway DX441X Intel Desktop PC - Intel...
When reading some disks it reads for awhile then it shows no disk.These are movies i rent,but it will read some disks.I have read manual but there is nothing useful.
If these are rental DVDs, they might be too scratched up for the DVD player to read. Look on the underside of the DVD and see if there are any scratches. If there are scratches, ask the rental place for replacement DVD
Mar 01, 2011 | JVC Televison & Video
Lg cd/dvd rw will not play or record. but will play mp-3
It should "play" commercially-produced audio CD disks.
With the correct software (PowerDVD, et cetera) it should "play" commercially-produced audio/video DVD disks.
It seems to be reading "data" disks (MP3 files are just "data" files), and passing them to your software (Windows Media Player, iTunes, WinAmp) for decoding and playing.
You need software (Nero, or AShampoo Burning, or ...) to be able to "burn" CD and DVD disks.
Jul 03, 2010 | Computers & Internet
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Disk error
It could be the lens on the laser. There are special cleaning disks for that.
Jun 18, 2017 | JVC DR-MV1S DVD Recorder/VCR
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Panasonic DMR-E20 DVD Recorder Logo
380 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
