LG Computer monitor stopped working
On Tuesday, my computer and monitor were working fine. I pushed the power button on the monitor to turn it off for a while and make the room darker, but I left the computer on. The next morning, I pushed the power button on the monitor again, but it would not turn on. I unplugged it, plugged it in again, tried a new outlet... but nothing is working. I just can't get it to power up at all.
It is less than two years old. The model is LG FLatron L1732TQ-BF. Might it have a fuse or something? Would turning it off like that affect the power cable somehow? Any tips?
Thank you,
Natalie
4 Suggested Answers
romsky79
  • 822 Answers
SOURCE: Computer monitor screen stays black
check secondary power supply budged capacitors and apply fresh solder. check also lamps connectors.
Posted on Jun 02, 2009
budmrtn
  • 11361 Answers
SOURCE: My model no is FLATRON L1752S-BF and serial no is
The LG Flatron L1752S is made in 2006. You can go to LG website here. I do not believe it is under warranty. http://www.lg.com/us/support/repair/support-warranty-claims.jsp
Posted on Apr 05, 2010
  • 12 Answers
SOURCE: Power problem with LG L204WT Flatron
If your LG L204WT will not power up all of a sudden, or takes long to power up, or dies after a while and it has not been exposed to lightning damage then in all likelihood the Electrolytic capacitors in its power supply has started to fail.
Unplug the unit from mains. To open it up, remove the 4 philips screws at the back. Then starting at the bottom corner use a small flat screw driver to wedge the front bezel loose. After removing the bezel the rear casing will also come off the panel. The circuitry case is taped to the panel with silver tape. Loosen the tape, lift the power supply. Carefully unplug the two sets of backlight cables, and the front panel controls to completely remove the circuitry case. Now remove the 4 screws holding the power board and then replace the following capacitors:
You can order caps from most electronic component stores.
You will need to replace:
C105: Electrolytic Cap, 47uF 50V 105 degrees C
C106: Electrolytic Cap, 1uF 50V 105 degrees C
C202,C206: Electrolytic Cap, 680uF 25V 105 degrees C
C203,C204, C205: Electrolytic Cap, 1000uF 25V 105 degrees C
You can always use a HIGHER voltage and a slightly HIGHER uF, and HIGHER temp rating but never lower.
Make 100% sure to observe the polarity when replacing the caps. Electrolytic caps have a clear negative marking stripe on the side coinciding with a black mark on the board.
Posted on Mar 23, 2013
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
Monitor Problem
What is the exact model of your screen?
Feb 22, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
Hello, I have a LG flatron w2234s and a week ago the screen started to shut down on its own while i'm using the computer or when it goes to sleep mode. The screen gives me the LG sign and just turns off...
First try it on another Pc, you'll know the root of the problem. If there's no problem on another pc then the problem would be with your video card/motherboard. If the problem is still the same on another Pc, then your monitor has internal problem. You better call up a technician, he/she will check it for you, must be Pcb problem. Good luck. Thanks for using FixYa.
Jun 04, 2010 | Computers & Internet
The monitor will not turn on. When power button
First--was it working?
Did it suddenly stop?
When you see the LG logo, then it goes away, does the power light turn from green to amber? Sounds like that doesn't happen.
So--if you are getting a signal, you should see something.
If there is no signal, then the power light should change from green to orange.
With no lights at all, I suspect a faulty monitor.
Feb 22, 2010 | Computers & Internet
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
Gateway screen not responding
Try Pushing together the body of monitor in middle top areaWhere the Word gateway is Imprinted ,Loose connection on ribbion probably,on mine ,but I think I got LUCKY here honestly,
Just try it before disassembly
Apr 11, 2009 | Gateway FPD2275W LCD Monitor
Cannot turn off monitor
It is problem with power settings. Start/Control Panel/Power Options -- and then pick a Power Scheme from the drop down list and make whatever modifications you want to the settings that power down your monitor
Feb 28, 2009 | Dell E196FP 19" LCD Monitor
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
