Fine Digital FineDrive 400 GPS Receiver Logo
Posted on Jun 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It said (cannot find map data files. please make sure the storage card is properly inserted I did. now what????
ChuckyMo
Level 2:
  • Expert 75 Answers
  • Posted on Oct 23, 2013
ChuckyMo
Expert
Level 2:
Answers
75
Questions
Helped
6970
Points
134
Your maps are currupted. Can't tell you where to find new ones. The company does not support map updates or have any old discs with maps for downloading from computers.
2 Related Answers
Anonymous
  • 107 Answers
  • Posted on Feb 22, 2008
SOURCE: FineDrive 400: Original SD card got corrupted!
you need to reload the firmware in the unit and reload the map data on the SD card, this will fix your issues. as finedrive is not around anymore, here are the files:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
Anonymous
  • 3 Answers
  • Posted on Mar 27, 2009
SOURCE: my nextar x3-08 wont read the sd card
I called Nextar and you have to let its battery drain completely and then plug it in to charge for 5 hours. I guess it a glitch in the system :(
Sony sat nav software
have you tryed your sony help line?
4helpful
My garmin 530hcx has locked up on the opening screen...is there a master reset sequence? I have removed the batteries and still won't work! Also, it won't shut off once turned on and locked...
f a device is locking up and has a long noise or beep when powering down, this is due to hidden data being transferred to the microSD data card. These hidden files and folders are being created by the computer and sent to the data card in addition to the maps, waypoints, routes, tracks and pictures that were selected. The following GPS units could experience this issue.
  • eTrex Legend Cx
  • eTrex Legend HCx
  • eTrex Venture Cx
  • eTrex Vista Cx
  • eTrex Vista HCx
  • GPSMAP 60Cx
  • GPSMAP 60CSx
  • GPSMAP 76Cx
  • GPSMAP 76CSx
  • Rino 520HCx
  • Rino 530HCx
To prevent this issue when the device is shutting down delete these extra unused or hidden files and folders from the data card. Examples of these folders are: .Trashes and .Spotlight-V100 folders. Since the Mac OS adds hidden files and folders to mounted removable drive volumes this process cannot be done on a Mac and will need to be done after every time the data card is mounted as a volume on a Mac.
To delete these folders the device will have to be placed into USB Mass Storage mode. To do this:
  1. Connect the device to the computer using the USB cable
  2. Go to the Main Menu
  3. Select Setup
  4. Select Interface
  5. Select USB Mass Storage Mode
The device is now in USB Mass Storage Mode. At this time a window should open on the computer desktop displaying Removable Disk at the top. The Garmin folder will be displayed. Open the Garmin folder.
Do NOT delete the the following files:
  • gmapsupp.img
  • gmapsupp.unl
  • gmapsupp.gma
These files contain supplemental mapping. If delete will cause the mapping to be erased or unviewable.
If there are other folders or files on the data card, delete these. Some of these files or folders may be hidden and therefore will need to be unhidden*. Once you have done so, please disconnect the device from the computer and power it up.
*Note: To Display a file folder that is hidden:
  1. Select the Tools option on the window that appears on the computer when the device is in USB Mass Storage Mode
  2. Select Folder Options
  3. Select View
  4. Open the Files and Folders folder
  5. Open the Hidden Files and Folders folder
  6. Select Show hidden files and folder
  7. Select Apply
  8. Select OK
Once all of the hidden files and folders have been removed from the microSD Card the unit will not
Sep 18, 2011 • Garmin GPS
Unit indicates mapcard not inserted properly but it is
card is possibly blank send it back. buy a marbella altina Nextar are unreliable GPS If in Australia see www,nettiser.com.au/marbella/
e3ven outside australia the maps are available for all countries and the unit is reliable and easy to service, also has a mkap backup service if registered.
5helpful
My nextar x3-08 wont read the sd card
My nextar W3G-01 won't load the map screen any more. One time as I was trying to make it work by flicking back and forth a message stating invalid or missing data file linkinfo.bin came up, but nothing...
I HAVE A SIMILAR PROBLEM WITH MY W3G-01. THE ERROR MESSAGE READS; CANNOT FIND MAP DATAFILES. PLEASE MAKE SURE THE STORAGE CARD IS PROPERLY INSERTED. I HAVE REMOVED CARD AND REINSURTED IT AND THE MESSAGE REAPPEARS.
Jul 19, 2008 • GPS
1helpful
2answers
Finedrive 400 Maps & data card
Ok So I now have these 2 files on my pc, virus free. One is the Map_SD and one is the Install_SD. I unzipped them to folders of the same name.
Can I simply copy and paste both folders into a 1gb sd card and it will work ( I have to buy an sd card so Id like to make sure)
Thanks
1helpful
2answers
install data
and the map data
Top Fine Digital GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
