Question about Sony Ericsson Walkman® W880i Cellular Phone
Water damage dried out phone now it won't switch on but there is a red flashing light by the (C) power button??
  • 1 more comment
  • moorelove90 Aug 23, 2008
    i spilt vodka on it and the speaker are all statiky
  • deano_austin Sep 29, 2008
    dropped it in a pint and have a red light come up when i try and turn it on anuy chance of gettin it fixd
  • laurab9 Oct 08, 2008
    Dropped my phone in some water, it now won't turn on and a red flashing light above the c/on-off button has appeared? Can anyone help?
Dried out phone but it is still dead, have i any chance of getting it going again?
Posted on Aug 22, 2008
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
My nokia 7230 is not starting, my daught had put it in a water but not soaked in water i removed it imm and dried, it was working then, except for the up n left navigation key and the disconnect button so...
Hi, when ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.
After, disassembling the phone is the next step.
Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the processyou are charging the battery of the phone.
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
You can visit the below link to learn more about flashing of phones.
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 26, 2011 | Nokia 7230 Cell Phone
No power my phone
PHONE IS DEAD WON'T COME ON
1. Water damage
2. Fall down
Jul 18, 2011 | Cell Phones
My Nokia E63 is not turning on, I've changed the battery, charged it with a desktop charger, on other phones it will on but on my e63, I won't just turn on. what am I to do.
1. Water damage
2. Fall down
Jul 05, 2011 | Nokia E63 Cell Phone
The "clean" light is flashing
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 18, 2011 | Whirlpool Dishwashers
I have htc p3400. i replaced the battery but my phone is not turning on. no indication that the battery is charging. (no orange light). when i switch on the charger, only once the light (red & green...
1. Water damage
2. Fall down
Jun 17, 2011 | Cell Phones
Hi I am not getting any Red from my printer
It's possible magenta ink to be finished, or the print head is dirty and it has dry ink on it. You must clean it with hot water. You must use the printer from time to time to avoid to dry the ink cartridge or print head.
Mar 08, 2011 | Canon i455 InkJet Photo Printer
My trackball isnt not responding when i selected something
Okay for future references do not bring your phone into the bathroom :) because this can cause water damage to the phone due to the humidity in there. Anyways there is something you can do remove the trackball to find out how click here after its removed you can check for water damage or any water that has collected there if you do find water damage or just water turn your phone off! Next after that I would leave the phone in a dry place to let the water evaporate do not stick "kleenex" or paper towel in there because u can get peices stuck in there and can cause problems for the trackball later on if you really want to stick something down there to soak up the water use cloth that has no chance of getting stuck and leaving something behind so after that reassemble your trackball with the ring and remember dont force it or you could break the ring and it should work if not just post back and I'll be happy to help you again.
Cheers,
Kyle
Jul 02, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
K800i sony ericsson not switching on
your phone software program is damage or over DL'
the best way to do is bring to the nearest Cellphone repair shop' and re-program it' special gadget and software is needed...:D
May 26, 2008 | Sony Ericsson K800i Cellular Phone
Nokia N70 doesn't display anything?
You have to open it up to dry it up with a hair dryer , there is still water inside the phone. Do not turn it on until you have dry up all the water other wise you will damage the phone. Good luck
Apr 29, 2008 | Nokia N70 Cellular Phone
Sony Ericsson Walkman® W880i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
