Question about Canon PC-920 Black and White Copier
Canon PC920 paper feed "clacking" & not working.
After a paper jam, I attempted to make a copy. I heard a clacking sound and the paper in the carriage would not feed. However, I can single-feed the paper from the side and the copier works fine without any noise.
  • Anonymous Mar 22, 2014
    paper jambs after fuser
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Posted on Aug 25, 2008
Hello, I got an error message 5C10. What does that
I just had this error message appear on my computer screen and the 6A00 on my MP830 printer at the same time. I heard this error mean a few things (paper jam, ink carriage stuck), though not sure what it does actually mean. I moved the carriage back-and-forth, blasted compressed air and checked for paper jams. When nothing worked, I looked inside and saw a lot of spilled ink, I'm guessing from not using genuine Canon ink. I blotted the inside with paper towels (use gloves!!),especially the far right, and took out the ink cartridges and blotted the carriage. I replaced everything, powered the printer off and on, and it worked fine. I would suggest first to slide the carriage back-and-forth and look for paper jams before cleaning the ink. Hope this works for you.
May 25, 2011 | Canon PIXMA MP830 All-In-One InkJet...
The paper won't feed and the paper jam light goes
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on emma.servis@gmail.com, if its Canon copier.
Jul 17, 2010 | Canon Office Equipment & Supplies
The paper in my canon 2270 is sticking every time it feeds. This only occured after we ran some books
Make sure the paper size dial is set correctly for size and orientation of paper loaded (on the front right corner of the paper tray). The copier will display paper jam every time if this dial is incorrectly set. After this has been confirmed, if it still jams, try cleaning the paper feed rollers with soapy water or isopropyl alcohol (make sure rollers are dry before attempting to copy again) Let me know, please
Oct 25, 2009 | Office Equipment & Supplies
I had a paper jam and got the paper out but still shows E2
E2-2 = No paper (ASF)
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error (bagian cleaning head)
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = ink absorber full or platen waste ink absorber full > reset dengan toolsnya
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
which error message exactly your printe show?
Sep 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Pc920 won't make copies
the noise could be the heat rollers have squared of this happens if the machine hasnt been used for a while the pressure makes a flat on the soft roller.. it cold also be the toner cartridge has settled. take it out and give it a good shake.. if you cansee if the scanner lamp and carriadge is moving when you run the copier up it mighht be saveable.. make sure the paper is new and dry as this can cause jams in hot section.. if you can see where the paper jam is when you do one copy check the guides as well and finally take the paper tray out and look at the condition of the rollers that feed the paper as they may be dirty and sliping the paper..Good Luck A
Jul 30, 2009 | Canon PC-920 Black and White Copier
Canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
May 26, 2009 | Canon PC-420 Copier
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
HP 6180 printer
henryandjane,
Look over on the wheel that will feed the paper mybe there is a tiny piece of paper on it and find the sensor for the paper mybe it is stack-up already
Jul 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
CANON PC920
POSSIBLE BAD EXPOSURE LAMP, SOUNDS FUNNY BUT THIS MODEL WILL SEND JAM CODE WITH BAD EXPOSURE LAMP. CHECK TO SEE IF LIGHT IS IN PREHEAT MODE. ALSO THE EXIT PAPER SWITCH GETS BROKEN OFF ON THIS MODEL...
Nov 29, 2007 | Office Equipment & Supplies
Canon PC-920 Black and White Copier Logo
294 people viewed this question
old marine
old marine
