Xerox xc520 I have inherited a xerox xc 520. When I plug it in 3 lights at the front start flashing. What does it mean? I haven't got the user manual. Can anyone help?
    Problem Solver:
  • 8 Answers
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum. Once you replace the drum, you need to reset the copier.
Posted on Aug 25, 2008
I have a Yamaha Cygnus XC 125, currently will not start, tried jumping the bike with no luck, no noise from ignition button or fuel pump, full tank fuel, unsure what to do, fuses are fine
Error 46 means no/poor charging or flat battery.
Check
Stator or rectifier. Check the plug on the rectifier they some times burn up.
3 wires from the stator should read less the .3 ohms across 1-2 2-3 1-3 pins.
May 28, 2017 | Yamaha Motorcycles
Tip
Xerox XD or XC Series Copier Drum Light Drum Unit Reset Procedure
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works on nearly all Xerox XD and XC Series copiers.
on Mar 20, 2010 | Office Equipment & Supplies
I have a number 4 and a letter H flashing
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models
Good Luck and Thank You for using Fixya
Jul 16, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
My xc 1040 the little triangle keep flashing red and wont let me do anything else
Hello sir; The red triangle indicator light on, it means need toner, just replace toner cartridge shpuld be fine.
Nov 04, 2009 | Xerox Office Equipment & Supplies
I need an Owners Manual / Service repair manual
I tried my best to find free copy of manual and found nothing, Xerox says that we have discontinued our support for this product since December 29, 2006. Well you can buy this manual from;
http://www.nodevice.com/manual/newmans/XC520-540-560-580smpdf/get11482.html
Best of Luck,
Regards;
Hassan
Jul 22, 2009 | Xerox Office Equipment & Supplies
Xc 1040 xerox Red light is flashing and the copier will not
On a XC 1040 machine either there is a jam on the fuser, the fuser switch fell out of place, or the sensor swich arm fell off the registration sensor.
Since we cannot see the machine we might understand what is taking place.
If the machine is turned off and back on and there is no red light, then the machine must be able to attempt to make a copy. If a copy does not come out, then there is problely some worn feed rolls.
If when the machine is turned on and there is a red light then th There can be some bad paper feed cluthes as well.There might be a paper stuck at either fuser assemly or paper feed roller areas.
Provide more description about the visuals on the machine.
Good luck.
Jul 15, 2009 | Xerox WorkCentre 4118 Network Kit...
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Xerox xc 1045
H3 is a fuser problem, check lamp or thermofuse
Oct 31, 2008 | Office Equipment & Supplies
Xerox XC 1020 copier code H4
With "H4" flashing press:
1.Clear button
2.Auto button then again
3.Clear button
4.Auto button
It should be done quickly. If it's done quickly enough all lights on display should go off.
5.Enter number 14 (as if you are making 14 copies).
6. Press START/COPY button.
The machine goes back to normal. If not, thermistor on the fuser (heater) should be replaced.
Sep 02, 2008 | Office Equipment & Supplies
Xerox xc 520
now you're testing my memory. The paper loads from the right side. You need a paper tray. The paper comes out on the left side. Also, the top is a moving platen (remember those?) so you need to have enough space around the copier for the top to slide left and right. Before buying a new drum, make sure you have a paper tray. No sense paying for a supply for something you cannot use. I need to check with a few people to see if I can find the reset sequence. It was in the manual, but like you, I no longer have one for that product.
Aug 25, 2008 | Office Equipment & Supplies
90 people viewed this question
k24674
jasbo
jasbo
