Question about Polaroid FLM-3732 Television
Green/blue vertical lines, no pix, screeching
If it gets a picture, it's intermittent... screeches, then has green/blue vertical lines... Is mine a capacitor problem, too?
  • Anonymous Sep 02, 2008
    I had the same symptoms,screeching in sound and picture breaking into lines.The caps were the problem.Don't worry about the 35volt vs.10 volt rating.Don't ever replace a cap with one that has a LOWER voltage rating OR a radically higher rating.For original 10 volt caps don't use 6 volt(they would probably blow up due to excess current leakage)and don't try to use 150 volt(over time they might do something called deforming that is peculiar to electrolytic caps.The 35 volt radio shack units will work just fine and are unlikely to give future problems.There is a third 1000 micrfarad cap not far from the other 2 that didn't look too good to me.I would suggest replacing that one while you are doing all the dissassembly to get to the others.
    Problem Solver:
  • 7 Answers
This is a cap problem too.There is a third 1000 microfarad cap near the other 2 I would suggest you replace while you are in there.The instructions are very good and if you follow them carefully it should be an easy repair.If you have a friend who does some electronics and are unsure of your ability it will be duck soup for anyone who can solder.
Posted on Sep 02, 2008
I have Samsung 58" Plasma model Pn58a550s1f that turns on and off with green lines and makes loud noises. Eventually fixes itself.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung Televison & Video
Green vertical lines & screeching noise
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts.It will make surf easy.
Feb 25, 2015 | Samsung LN46D630 46 inch LCD 630 Series TV
Samsung TV started Green Vertical Lines screeching sound tv turns off and cable box resets up to 15 minutes before clear picture and sound work.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 20, 2015 | Samsung Televison & Video
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Wont turn on
there may be a short in the system. Bad news: You should have a licensed pro help you diagnose it and fix it. Good news: its fixable.
Aug 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
SCREECHING AUDIO
My Vizio (don't know model # off hand, 32" bought at WalMart in Jan), is doing the same thing. It did it once the day I set it up; thinking it was just a glitch or something about my lack of knowledge with HDTVs, I powered it off (the hard way, yanking the power cord, as it won't turn off any other way) and restarted it, everything seemed OK. It did it again around April, same thing, just a glitch I figured. I changed some cables, attached more devices, and it has been doing it about twice a week now.
Sometimes it is the full video lockup, with vertical green lines, and full blast audio screech. A couple times it has only partially locked up the video (green vert lines, but still some movement), and no audio screech. Did it last night most recently, hence my google search.
Anyway, my point is, this is probably more common than we were both thinking, and they know just from your description what the problem is. I would try to have them repair such a known-issue free of charge, even out of warranty.
Jul 19, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
