Question about Microsoft Xbox 360 Console
Xbox 360 My xbox 360 av port is broken. Where can I find an av port to replace it?
READ THIS FIRST!
If you have the 3 red lights or any other common Xbox 360 problems suh as the
  • 3 red lights
  • 2 red lights
  • 1 red light
  • DVD drive read errors
You can learn to fix these problems for free.
There are loads of these guides out there that all claim to fix the problem however you should read the article below that will shed some real light on whether or not you can repair your Xbox 360 yourself!
Make sure you read the article first to avoid being scammed!
FREE ARTICLE REVEALS THE TRUTH ABOUT XBOX 360 REPAIR GUIDES HERE!
Posted on Sep 02, 2008
  • 89 Answers
If it is under warranty maybe you can ask the manufacturer if they can replace it or yuo can try to check this forum website also:
http://forums.xbox-scene.com/index.php?s=a80517f4a3a729e4ea6e710fc69b944f&showtopic=656926&pid=4316084&st=0&#entry4316084
Posted on Aug 25, 2008
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 green screen after turning on
i doubt if its the xbox try replacing the av wires and see what it does maybe the av wire has a short in it
May 07, 2009 | Microsoft Xbox 360 Console
Red flashing lights
This issue may occur for one of the following reasons: • The audio-visual (AV) cable is not connected correctly or is not plugged in to your Xbox 360 console. • The console is not detecting the cable.This issue does not occur if the AV cable is plugged incorrectly into a television, a stereo, or a VCR.
Note This issue occurs only on Xbox 360 consoles that do not have a High Definition Multimedia Interface (HDMI) AV port.
Apr 11, 2009 | Microsoft Xbox 360 Console
My xbox 360 shows no video but I can here sound this happened after trying to connect a video game surround sound chair to it...can anyone help.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. This means that the AV PORT is broken.
4. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
Mar 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 has no video or sound, but has green lights
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
The main reason why its acting that way its possible that the AV PORT is faulty.
Mar 28, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Xbox 360 problem
maye the damaged in the av cable or the port of the av cable in the xbox ....... so 2 see where's the problem by buying a new av cable so if it works so the problem was in the old cable if it still not working so i think that the prob will be in the xbox itself
Sep 18, 2008 | Microsoft Xbox 360 Console
Rockband 360 problem
have you checked the batteries? also try re-syncing them to the 360. are you using wireless or wired? if wired, sometimes the usb ports get worn out, try using the one in the back above the av port. good luck!
Jul 31, 2008 | MTV Games Rock Band Bundle for Xbox 360
Microsoft Xbox 360 Console Logo
113 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
