Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
We just got a newish Maytag Atlantis and it's doing the same thing as my old washing machine. The machine fills and agitates just fine, but it will just continue to agitate the same water (never drain and spin) all the way to the end of the cycle. If you lift the lid, the drain and spin will engage and it spins fine. The Maytag worked correctly on the first try (it had been a week since I did laundry), but on the second load it started to do exactly what my previous machine did. Could it be something with the drain? Power?
  • 2 more comments
  • Carex Aug 22, 2008
    Based on my internet research, that seems right. But what is strange is that both machines have the same issue. My old one did the exact same thing (which is why we just bought the newer one). In addition, the new one ran perfectly for the first load (I was jubilant). I know it can be due to chance that both machines have the same problem, but it seems odd that they would, and odd that the newer machine would work right the first time. I wondered if there was some back pressure from the drainage system that reset the machine in anticipation of the drainage/spin.
  • Anonymous Nov 04, 2008
    I have a Maytag Atlantis MAV7650AWW it agitates from the beginning
    to the end without going into the spin and risk cycle. If you turn the timer
    manually to the spin cycle it will work properly and all of the water drains. I also smell an odor coming from the washer which I have no clue, unplugged, Help!!
  • tmthycooper Nov 10, 2008
    Maytag lat8435 aae: The spin cycle does not drain properly. The hoses are not blocked and water drain pump works ok although the belt is slightly loose.
  • bchiselbrook Nov 20, 2008
    I have a similiar problem with my Maytag Atlantis top load washer. Mine seems to spin and drain fine, though it is squeeky and noisy. But the problem with the last load we did was that I started detecting a burning smell when it was in the agitating mode?
  • 22 Answers
Your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
Maytag Atlantis washing machine does not rinse, spin or drain
You need to make sure that the switch on the door/lid is making a connection. If the lid is not closing completely, clear whatever is not letting it close. However, if it's closing but still not working you may need to replace the switch. I have had them go bad an not make a connection when the lid closes.
Mar 31, 2014 | Maytag Washing Machines
My mvwc300vw1 won't spin unless you lift the lid up to activate it
I'm not sure what you mean by "activate it." Are you are manually pressing down on the lid switch or are you saying that lifting the lid starts the spin cycle? You may just need to adjust it. For whatever reason the actuator on the lid isn't pushing the switch far enough to activate it. It is possible that the actuator broke in some weird way that makes it contact the switch when the lid is opened. Regardless the spin cycle should cease when the lid is opened. The actuator is the wire hinge on the left side of of the lid. They always break where the screws connect them to the lid so you should be able to see it by lifting the lid. You can go here for manuals and exploded views of your machine. The hidden lid switch and actuator are clearly visible if you click the "Top and Cabinet" diagram.
Now i want to say something about your machine. First to be fair i don't know what the reviews of this machine might have been and I've never owned one, but if it serves you well hold on to it. Maytag doesn't make them like that anymore. In fact Maytag doesn't really make them anymore. That repairman died years ago and was never replaced. I'd take a machine like yours (with manual controls and no brain) over every smart h.e. machine i've ever had the misfortune to work on or operate. Sure they save water and they are quiet now but the drain pumps are junk fixing to bust and in my opinion the reason people experience mold and odor problems. They oversuds chronically and then have to sit while the machine decides when and how you can proceed. Doors lock shut at the most inopportune times. Control boards cost hundreds of dollars to replace and diagnosing problems on a "smart machine" can sometimes be more than a little baffling. So treasure it. Just sayin.
Jan 01, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Machine will fill with water but will not do any other thing. Will not spin, drain or wash. Stopped in the middle of a load.
check to be sure the safety switch on the lid is working, It will fill if its not, But not much else,
Jun 06, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7200 doesnt drain at end of rinse goes to OFF
It sounds like it may be the lid switch. It may be as simple as adjusting or tightening. But ultimately it may need replacement.. Hope this helps
Apr 04, 2009 | Maytag Atlantis MAV7000
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine fills, and thats it.. will not do anything else
There is a problem with the lid. Push ******* the front of the lid. It should work. Mine has been doing this for 6 years.
Dec 03, 2008 | Maytag MAV6200 Top Load Washer
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
951 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
