There is a small/large leek in the base of the unit with the filler module probably as i have just removed mine cleaned it emptied all the water from inside the base, tightened the hoses properly and now its running, i was a hour to repair i am a technical minded person so i had no problems but if you are unsure please contact service engineer any local repair man should be able to fix it! there was a switch controlled by a foat in the base as my unit had a leak this is what cause continuious bleeps and 3 flashing lights!!! good luck
Not sure of my model number as it's integrated. It's timer is still on and showing 11 mins left but it's not doing anything.
all the program lights start flashing when i open the machine but when i set it at the beginning it won't start.
HAVE THE SAME PROBLEM WORKED FINE THEN STOPPED HALF WAY THROUGH NOW HAVE 3 LIGHTS FLASHING, BLEEPING AND IT SOUNDS AS IT IT WONT DRAIN ETC. HOW CAN I FIX IT. BROUGHT IT FROM MFI 4 MONTHS AGO AND ITS GOT A 4 YEAR WARRENTY WHAT A JOKE
same as above, 4 months old seconed time used.
Exactly the same problem here! Can't even get through to Diplomat tech help, i've also got 4 year warranty. what a joke!
I have the same problem.
anyone know of diplomats tech support number as the one on my booklet is closed down........not happy about this , i think its the pump not letting water in anyone had a solution?
hi
i have the same 3 lights flashing and no idea what to do. no one will help as we got it from mfi with kitchen
absolute joke
tony
harlow
