Question about PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 Motherboard
Cannot get motherboard to boot from hard drive
Only options that seem to be available to boot from are the CD ROM or the floppy. I have loaded Windows XP Pro on the Hardrive but I cannot get the OS to load from the Harddrive so I can complete the installation process
    Sergeant:
    Novelist:
  • 166 Answers
Have you checked the Bios to see if its actually recognising the hard drive?
Turn on the computer and I think on your bios it should be the f2 key to get into the bios, if its not detecting the hard drive you may just have a jumper on the drive set wrong
Let me know if I can be of further assistance
Posted on Aug 22, 2008
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
When i try boot my dell xps 420 it states that there is no boot device available. Why does it say this?
A boot device stores your operating system (i.e. Windows), and is usually your hard drive, but can be any storage medium such as a floppy, usb flash drive, or even a cd rom. When you turn your computer on, your motherboard looks for your OS on any of the storage devices specified in your bios, in the order specified to look first (Ex. Boot order: 1. CD-Rom, 2. Floppy, 3. Hard Drive, 4. Network). Your Dell is telling you that it can't find Windows on any of these devices. Most likely cause is that your hard drive stopped working, your Windows boot.ini file became corrupted, or you have a USB device plugged into your computer, and it needs to be unplugged before turning on your computer.
Jul 05, 2010 | Dell XPS 420 PC Desktop
Dell Optiplex GX50 won't load windows OS
Which cdrom is it? Is it a windows XP cd? This is an older PC? Does it have a floppy disk drive? Try downloading from Barts a bootable floppy disk, set boot order to floppy in BIOS, change to cdrom drive letter after booting to floppy (D:?)
got to I386 folder and set up from there.
More info would be helpful.
Jul 09, 2009 | Dell Optiplex GX50 Intel Desktop PC -...
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
Mar 05, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
About harddisk
If this is a newer system, this issue is the XP CD you are using doesn't have the needed hard drive controller driver it needs to see the Hard Drive.
Because this is Windows XP, you have only 2 options to resolve the issue. XP will only load a controller driver during install from one of 2 locations. Either a floppy diskette drive or from the XP Cd itself. XP has controller drivers for most systems available at the time the CD was burned, but newer systems, especially ones with SATA hard drives do not have supported drivers in XP CD images. You options are as follows:
  1. Connect a USB Floppy Diskette drive to the system, download the needed driver (If one is available) copy the extracted driver files to the root directory of a floppy diskette and put the diskette in the Floppy drive, then boot the XP CD again. The driver should load automatically if the floppy is in A: Drive when you boot to the CD.
  2. The second option requires slipstreaming the driver (Same one downloaded to a floppy in 1) into the XP image. (This takes a good bit of knowledge in bootable cd creation)
If all this seems to be quite the hassle, then install Vista,
Feb 17, 2009 | HP Computers & Internet
Os instalation will not load
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Sep 26, 2008 | Computers & Internet
Cd rom message "no emulation" when booting the windows xp installer
when i install my windows xp professional i get a message prompting BOOT TO ATAPI CD-ROM: "NO EMULATION".... how can i fix this?Pls help me on this
Jun 07, 2008 | ASUS P4SP-MX Motherboard
Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Loading Windows 2000 on a formated hard drive
Try detecting cd rom in bios and boot from Cd rom. and then istall windows.
If not you should have drivers in floppy during installation it will ask for drivers F6 [function key]
Best Regards
rafique
Feb 18, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
Acer Aspire 3610 laptop - Windows XP error
on a friend's Windows 98 SE or Windows ME computer, create a floppy "Startup disk". Insert in your pc floppy drive and turn on. If floppy drive was not accessed, then get to BIOS and ensure "Boot from floppy drive" is set prior to "boot from hard drive". Once at first screen, select "Boot with CD-ROM driver". Insert CD-ROM and initiate entire re-install of Windows. Windows may do some self-restarting. At first restart do this: get to BIOS and ensure "Boot from hard drive" is set prior to "boot from floppy drive".
Jun 05, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
124 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
