Recording Disk Problem Cannot Record On This Disk E4 54037380
  • kez69 Sep 18, 2008
    tried all sorts of disks it wont record on them says e4
  • kevmark58 Oct 15, 2008
    I have tried three different +R discs and none will work. The player says there is a problem with the disc, wants to restart, self-check and then says the same thing....How can three different manufacturer discs all be problems?
  • 4 Answers
This seems to be a common problem on DVD recorders.
If a DVD Lens cleaner (with brushes) fails to fix the problem, then it could be that you have
grease particles on the lens. Do the following:
Note. If unit is still under warranty, you may nullify this by opening unit up
You will need:
Screwdrivers as necessary
Cotton Bud sticks (also known as Q-tips)
Isoproponal/Isopropyl Alcohol (small bottle comes with some CD/DVD cleaners)
Compressed Air cannister/aerosol
1. After disconnecting unit, leave standing for 15 minutes
2. Unscrew lid and remove
3. Carefully remove DVD lens cover
4. Blast whole area with compressed air to remove dust
5. Dip one end of cotton bud in Isoproponal, and very carefully wipe DVD lens (just one wipe
should do.)
6. Now wipe lens with dry end of cotton bud, and leave a few seconds to dry
7. Carefully replace DVD lens cover (watch out for ribbon cables)
8. Replace Lid
9. Reconnect, switch on and test
After I'd tried every other way possible, this method finally worked for me!
Posted on Nov 11, 2009
4 Suggested Answers
SOURCE: Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
Posted on Jun 24, 2008
SOURCE: Funai DRV-B2737 Error message
Try using old-fashioned 2x DVD-RW discs, eg the cheap ones from Datawrite.
This seems to work in my machine MOST of the time.
Posted on Sep 12, 2008
  • 4 Answers
SOURCE: recording error E4 54037380
This seems to be a common problem on all DVD players.
You will need:
should do.)
8. Replace Lid
Error code recording stopped. Problem with record buffer
I've done some searching this seems very proprietary, I would first try contacting the manufacturer directly to see if t hey can shed some light on this issue.
Jan 23, 2015 | Tascam X-48 48-track Hybrid Hard Disk...
I have JVC Hard Disk Camcorder GZ-MG145AA, my problem is everytime to record it the counter of recording is Red flash..means cannot record to my SD Card any Brand or to hard disk is say hdd Failure no...
you should check out your sd card whether it has virus or not or you may try to format you card.I think it may help you.... if not let me know i'll give you other solutions.
Apr 06, 2013 | JVC Everio G Camcorder
My tas cam ld-74 will not record me at all i can here me thru my headset but i cannot record with my recording software
If you can hear the mike with your headset, I would assume that there is no electronic problem. Check the disk space on your PC to see if the disk is full (a full disk would prevent the software from recording). Check to see if you have the output file defined and targeted to a disk drive that has free space.
Dec 14, 2010 | Tascam LD-74 Professional Microphone
I have a JVC DR-M100 DVD recorder that will not record but plays.
Most likely has developed a problem with the laser pick up it would probably be cheaper to replace. Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | Televison & Video
Hi, Have just purchased Samsung DVD HDD recorder (DVD-SH855). Everything works great except the timer recording. When i schedule a recording, the system wont start recording. The recording light flashes...
I had the same issue. It turns out that the recorder has to be switched off otherwise it won't record. The unit will power itself on at the scheduled time and record your program. It doesn't make any sense to me why this would be a requirement but it solved the problem for me.
Jul 06, 2008 | Televison & Video
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Invalid disc prompt,whenever i install a disc
This is a dedicated audio recorder. Therefore, you must use dedicated audio discs (not data discs). You can tell the difference as audio discs specify the recording time (usually 80mins) instead of data capacity (usually 700MB).
When you have the right disc inserted, press the record button & it will go into record standby, ready to record. First, set a level, then press record again, and you are recording.
Jan 09, 2008 | KLH CDR2000 2-Disc CD Recorder
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
