Question about Compaq Presario 700 470024-192 Notebook
Mic not working
Due to absence of sound driver
  • 68 Answers
SOURCE:
How to fix and install the built in microphone of my P-78What's your problem?
LOL, Windows 7 is like it's predecessor Vista. Same people wrote it.
Have you made sure you have the mic's volume turned up? Have you selected the mic in the Audio and Sound properties?
Look at the Audio and Sound properties in the Control Panel and make sure everything is ok. The Mic has to be selected as a Recording Device.
Apr 10, 2012 | Computers & Internet
Hello fixya. I just reinstalled windows 7 for my acer aspire 5943G but for some reason i cant get the mic in the computer nor the mic in my headset to work, i dont know if its because i need a driver,...
Check the device manager to see if a microphone is installed. If it is, it may not be installed correctly due to a missing driver or wrong driver. If you find a mic installed, right click and get the properties. Find the tab that says Update driver and allow the laptop to connect to the internet to find the right driver. If no microphone is detected, you can manually install the microphone through the Control Panel under Devices/ Add Hardware. From there, you will select microphone and be given the option to either install it with a disk or by selecting the manufacturer/model.
Jul 20, 2011 | Acer Aspire One PC Notebook
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
I have no sound at all..What can i do?
Hello and Welcome to FixYa!
This is usually due to the absence of Audio drivers for your PC, kindly mention the brand and model of your machine, so that I may help you out finding the correct drivers.
waiting.. Concerned, Waqar
Oct 20, 2010 | Computers & Internet
No sound my motherboard simm-in 945 gc-1333
Absence of sound could be due to the missing audio driver.
Go to this link and download the audio driver for the version 6.0(available version is 6.0.1.5969)
http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=303
Install this driver.After installation restart your computer, the sound should work on your computer.
Jun 07, 2010 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Properly connecting the mic cable to the pins. my mic is currently in a state of repair due to the absence of the original cable.
For low impedance A3F/A3M, two wires with Shield
Pin 1 is ground/shield
Pin 2 is hot or +
Pin 3 is cold or -
For high impedance A3F/A3M, one wire with Shield
Pin 2 is hot
Pin 3 is not used.
Feb 21, 2010 | Audio Players & Recorders
HELP! My new compaq presario cq60 built in microphone wont work. I need help fast, major school project due in two days. My mic worked before, I disabled it because i was trying to so some streaming...
Do you have two mics or not,well if you have one you may have to delete one of them or both.Reboot the computer windows will install the drivers and this should fix this If not un-install the sound card drivers.Windows should reinstall once you reboot.However before you do make sure you have a copy of the sound drivers to reinstall.
Good luck
Sep 12, 2009 | Compaq Computers & Internet
Problem with sound device
this is due to absence of sound driver in ur pc.....
install appropiate sound driver and then play ur songs...
May 16, 2009 | Microsoft Windows XP Professional
I messed with my sound
echo due to playback setting on mic controls. ??
Go to sound properties and enable all slider controls both for Playback and Recording. Look at Recording sliders and mute any that you don't need (esp. Mic Playback).
Aug 03, 2008 | Acer Aspire 5610-4648 Notebook
Compaq Presario 700 470024-192 Notebook Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
