Acer aspire 3004 WLCi won't power on
The computer has only the green battery LED illuminated with power supply plugged in and it will not power on. There is 19 volts on the power supply. Measuring across the battery terminals from the first and last one there is 18 volts DC. If you unplug the power supply the green battery LED goes off. Unplugging the power supply and re-pluugging it in has the battery LED cycle from yellow to green after about 5 seconds. I have ohmed across the switch for the disply and it opens and closes.
  • Anonymous Sep 22, 2008
    exact same issue on an Aspire 9504WSMI, same led cycle, wont'start up after it went intot hibernating cycle
    Scholar:
  • 86 Answers
Often times when laptop won't power on, it's jack on the back where the power supply plugs in. It needs to be disassembled, soldered back together and that should fix it. Good luck!
Posted on Jul 26, 2009
How about the games on this kind of laptop??
Have a googd graphic game like Warcraft Call of duty ETc...?
Posted on Jan 11, 2010
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
My acer aspire 5735z won't switch on.
Solution posted in your latest post,
http://www.fixya.com/support/t11566511-acer_aspire_5735z_doen_39_t_turn_just
Feb 03, 2012 | Computers & Internet
Sundenly it shutdown and never be open again
Hi Good day!! it is a Power supply failure, check the power cord maybe it loosen up. re-plug your power cord. if still not turning on, open your PC and check your motherboard there should be a green led light on. if the green led is not on. maybe your power supply give up, i suggest that you replace your power supply.
Oct 19, 2010 | Acer Aspire L310 (ASL310UD631A) PC...
Battery not charging
As you have tried to replace battery and still new battery is not getting charged in this case it seems there is hardware problem. Circuit which allows battery to charge is not working.
Apr 29, 2010 | Acer Aspire 3000 Notebook
Acer aspire 3610 power lead transformer green light is on before plugging into laptop then goes out when plugged in.acer has nothing working, totaly dead any ideas?
If the power LED is lit before connecting to your laptop and then goes out as soon as you connect to your laptop, then you either have a short circuit in the power supply module of your laptop, or you battery is causing the fault.
Remove the battery and try again. If it powers up the battery needs replacing. If the problem is still the same then you need someone to look at the power supply module in the laptop
Mar 09, 2010 | Acer Aspire 3610 Notebook
Acer aspire 5552nwxmi notebook can't power on.
Unplug the battery and power supply from the laptop, then press and hold the power button for 25sec(No battert and power supply), then connect the cable back to laptop, then try to turn on the computer, if its turning on hten connect battery back to laptop...
Nov 24, 2009 | Acer Computers & Internet
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5100-5022 will not power up, power supply OK
maybe your computers battery is burned or maybe it's leaking
Dec 20, 2008 | Acer Aspire 5100 Notebook
3004 wlci
Here are sites that carry a replacement:
http://www.google.com/products?hl=en&q=Aspire+3004WLCi+battery+replacement&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 30, 2008 | Acer Aspire 3004WLCi Notebook
Computers & Internet Logo
341 people viewed this question
David Payne
David Payne
