Question about Husqvarna Designer I
Misalignment when embroidering with husqvarna designer 1
All of a sudden in the middle of an embroidery my machine is starting to move over about a 1/4 inch and finish the rest of the embroidery misaligned. This consistiantly is happening at the same spot on each individual design and usually occusr on the second color. Any suggeston as how to re-calibrate the machine (not the touch screen.. that is fine)?
thank you very much! I am in the middle of a huge wholesale order and vrey stressed for time!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 196 Answers
Sorry that I did not see this sooner.
It sounds like you should have your embroidery unit serviced. Sometimes they will accumulate lint on the slide rods and it inhibits the movement of the mechanism as if you were to bump into it while it is trying to move.
Quite often, this will happen repeatedly in the same point in the design and make people think that there may be something wrong with the design. But, usually it is just that the embroidery unit can't move freely.
Posted on Sep 30, 2008
SOURCE:
How do I find out the embroidery time on my Viking Designer 1 sewing machine?
Hi there, If your trying to find out how long it took you to embroider something, You need to go to your touch screen menu- touch Set- then down at the bottom left of this screen and touch More- three (3) times you'll get to where it says Running time:(It's the 3rd Selection) There it will actually show you the total running time (Sewing and Embroidery If you haven't zeroed it out by hitting the zero (0) next to that selection.) You can do this on the touch screen with the embroidery unit on or off. You need to touch the zero (0) to zero out your time before you start an embroidery project. Once you've done this and you've finished an embroidery you can check how long it took by the touch screen menu- Set- touch More 3 times and there you will see how long on the Running time it took to embroider your design. I hope that helped. The total time your machine has ran (Embroidery and Sewing) is kept in Memory on the Service Screen that your Technician gets into when he services your machine. So your not actually wiping out that. The Set menu is just for you to keep track of how long your machine sews or embroiders something pretty much. I hope that helped you out with your question. Happy Sewing!! Kathy
Nov 19, 2010 | Husqvarna Designer I
I bought a new embroidery unit for my designer 1 when I but it on it makes e terible noise and says to slide of hoop and clear position for i . embroidery position'But it won't go into embroidery...
Don't know for sure what is happening, but you should not put on a hoop until you are actually ready to embroider. The unit goes on while the machine is turned off; turn on the machine; it will make a noise; you should get a pop-up on your screen to Calibrate the unit. Touch this button, and the arm moves into position ready. Load your design and choose the correct hoop then put the hoop and project on the machine. Also be sure that your design will fit in the hoop selected.
Sep 01, 2010 | Husqvarna Designer I
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
Embroidery arm won't park or go in position on hoop to embroider
You may need to have the embroidery unit serviced. The slide rods in the embroidery unit will get dirty over time and must be cleaned and lubricated. If not, the mechanism can not slide freely and you will be unable to keep the unit calibrated while stitching a design.
You could attempt to disassemble and clean it yourself, but if you bring it to a repair center in pieces or improperly assemble your repair is going to cost a lot more than it will if you go today.
Apr 19, 2009 | Husqvarna Designer I
Husqvarna Scandinavia 300 not embroidering desgin correctly.
more than likely its the main pc board but if you had another emb unit you could put that on your machine and if it works fine then its the board inside the emb unit
Apr 16, 2009 | Husqvarna Sewing Machines
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
I am trying to embroider something for the first time on my viking #1 husqvarna. Do I need presser foot Q/ or R/ .If it's R,I can't find it-what does it look like? I need someone to walk me thru the steps...
embroider on #1+:
If it's a #1+ I recommend the Q (the spring works better) it's hard to put on, but worth it.
Here we go:
1>Turn off machine (always when installing or removing embroidery unit)
2>Install Q Foot. Always leave presser foot pressure (on left end of machine) at 6 for presser foot Q
3>Insert Embroidery Card
4>Insert Embroidery cassette (matching #’s with card)
5>turn on machine
6>Turn on embroidery unit (on cassette)
7>Select design
7>Thread for color 1
8>press reverse to start the machine embroidering....weeeeeeeee!
Jan 18, 2009 | Husqvarna Viking 1
Freezing problem with d1 machine embroidery and regular sewing.
there was a recall for the designer 1 machines. visit husqvarna's website.
Nov 10, 2008 | Husqvarna Designer I
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
Sewing Machines Logo
230 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
