Question about Casio Exilim EX-P700 Digital Camera
Why are my flash images out of focus? - Casio Exilim EX-P700 Digital Camera
    Scholar:
  • 114 Answers
This could be due to any of the following reasons. 1) A dirty lens can cause whitish blurring of an image. 2) Light from the flash reflected back from the subject can cause blurring and a feeling that the image is out of focus. 3) In total darkness when AF measurements are impossible, the camera focuses for about 2 meters. Subjects that are closer or further will be out of focus. The Auto Focus Frame is red when AF measurements are impossible. In this case, use manual focus (MF).
Posted on Aug 29, 2005
What is it features ?
MPN Capture 1300 Key Features Resolution 1.3 Megapixel LCD Screen Size 1.5 in. Digital Zoom 2x Lens Interchangeable Lens Not Interchangeable Lenses Focus Type Fixed Focus Image Quality Image Sensor Type CMOS Camera Resolution 1.3 Megapixel Image Resolutions 640 x 480 • 320 x 240 • 176 x 144 Exposure Control Aperture Range f3 (w) Storage Memory Type CompactFlash Card Type I Built-in Memory Size 8 MB Compression Modes Fine • SuperFine • Normal Compression Type JPEG Flash Flash Type Built-In Flash Functions Flash Off • Auto Flash • Fill-in Flash Viewfinder / Display Viewfinder Optical LCD Screen With LCD Screen LCD Protected Position Without LCD Protected Position Interfaces Interface Type USB Power Supply Battery Type 4 x AA Batteries Included Features Built-in MP3 Player Unknown Built-in Microphone Without Built-in Microphone Built-in Speaker Without Built-in Speaker Tripod Mount With Tripod Mount System Requirements Operating System Microsoft Windows 2000 • Microsoft Windows 98 • Microsoft Windows ME • Microsoft Windows NT • Microsoft Windows XP Warranty Warranty 1 Year Miscellaneous Included Accessories 4 x AA Batteries • Software • USB Cable • Hand Strap UPC 647499779101
Mar 22, 2011 | Veo Capture 1300 Digital Camera
Hello! When I attach the flash on my Nikon D200, it fires even while I'm focusing or just when I touch the trigger button. Any ideas? The flash is not firing like that while not on the camera.
The flash on the camera is being used to throw light for the lens to focus, unless the flash has a setting / the camera has a setting to fix this.... I would assume this as a normal behaviour.
Just to be sure that i'm thinking the same lines as you - your flashes that happen while focusing will be short bursts and when you take the final image you still have a significantly higher powered flash.
Dec 25, 2010 | Nikon D200 Body Only Digital Camera
Focus problem. Coolpix 5000 mounted on Nikon microsocope for photographing tissue slides. Perfect digital images for years; now 90% poorly focused. Image viewed through microscope in perfect focus, image...
If you are initiating the shutter manually, it is quite possible that the camera has become very slightly loose at the F-mount. So, when you press the shutter button, the movement though it may be extremely slight, is shaking the camera at the exact moment you are taking the picture.
Make sure that the camera is tight to the F mount and that the F mount is secure to the microscope.
If you are initiating exposure via software, it is still possible that there is still some slight movement on your desk.
Remember, the slightest movement is magnified many, many times to the camera.
Dec 18, 2010 | Nikon Coolpix 5000 Digital Camera
Images are blurred
Blurred images can have different reasons. Greasy lens, camera shake or focus error.
You can clean a greasy lens with a lens-cleaner solution and lens-paper.
Camera shake will (most likely) only occur on images taken without the flash. Most likely there will be a warning on the display if risk of shake. it's a hand with an "!". Focus error will usually also give a warning in the display.
May 09, 2010 | Fuji FinePix S2000hd Digital Camera
Olympus E520 Focus problem
will watch this post have same problem with focus especialiy indoor flash shots. a lot out of focus
May 30, 2009 | Olympus EVOLT E-510 Body Only Digital...
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Double images
Needs convergence circuit repair----Replace STK IC's and
check for burnt resistors or open fuses.Then touch flash focus..
Let me know............T.
Nov 01, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Camera doesn't focus
There are many reasons why images can appear out of focus. strangely if you think about it it is not focusing per se like photographic cameras the focus is at infinity by default- from about 50cm - out So if the images appear out of focus these are some of the reasons shots taken in low light with a low ASA setting resulting in long exposure -thus camera shake. Focus hunting- there are various methods used but if the mechanism cannot 'lock' onto something the focus motor will 'hunt' Faulty zoom Optic Zoom mechanism. Inadvertently set to 'Macro' mode Grease on the lens Careful checking of the camera- its settings- with the manual is essential before declaring the camera faulty Don't forget the paper manual is a nodensed version of the full manual on the software disk.
Sep 02, 2007 | Cameras
AF flashing green, red AF sign on screen - won't take pictures
When you depress the picture button you should both hear the camera making motor noises and see the image focus changing as it seeks the proper focus for the image. If no focus movement takes place and you hear nothing then the focus motor is either completely jammed or malfunctioning. Alternatively focus movement may take place but it never finds the right focus point. Or you may hear a buzzing or clicking sound when it should be focusing. These symptoms can be caused by impact or, more commonly, sand or other contaminants making their way into the delicate system which moves the focus element. The camera will require professional repair in either of these cases. David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix 4600 Digital Camera
Taking pictures
This could be due to a jammed lens element preventing the camera from focusing properly. When you push the button the camera attempts to focus the image before it takes the picture. If the focus component in the lens is not moving properly it cannot focus and thus will not take the picture. Do you see the camera attempt to focus the image when you press down the button? If it does not make any noises when you push the button, and the camera does not attempt to focus the image then it is most likely a jammed or malfunctioning focus motor. This would require professional repair.
Feb 19, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Casio Exilim EX-P700 Digital Camera Logo
107 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
