Question about NCR 7167 Thermal Printer
Ncr 7167 pcb with feed paper button
Hi expert have this pcb any number of part? i search because is damage
and the rotary knife too!!
thanks!!
  • rayad_77 Aug 22, 2008
    the number of pcb i need is up of de the printer have a feed paper button
  • 33 Answers
WE HAVE PLENTY OF THESE IN STOCK! <-- NCR Technician now Sales Rep... WE CAN REPAIR THIS!
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Posted on Jan 15, 2009
How do i install 7167 printer ncr
Welcome to Fixya
Connect the ccommunication cable to your computer. Connect the cash drawer cable to the printer and cash drawer. After all cable are connected, install the drivers disk that came with it. Please click here.
Thank you for using Fixya!
Aug 09, 2011 | NCR 7167 Thermal Printer
DRIVERS FOR THERMICAL PRINTER 7197 WINDOWS 7
I have ncr thermal printer 7197, and i have to use windows XP .this printer is not running in my system with his driver.plese you solve my problem
Feb 17, 2011 | NCR 7167 Thermal Printer
Where can I obtain a parts diagram for the NCR 7167-1015 POS printer?
feel free to email me this question later... We do have these part books in stock, and could easily copy a page and send it over for you.
Brian Wethern
wethernb@capcom-ncr.com
Capital Computer Group, LLC
651-405-8293
www.capcom-ncr.com
We specialize in the NCR arena, also have many other point of sale needs.
Free bench testing equipment failure on any p.o.s hardware item.
Jan 20, 2010 | NCR 7167 Thermal Printer
I NEED TO DOWNLOAD THE DRIVERS FOR NCR 7167 . ANY IDEA ?
Try the following page. I do not know what this device does so I could not explore any further, but you will:
http://www5.ncr.com/support/support_drivers_patches.asp?Class=External\display
good luck!
Oct 30, 2009 | NCR 7167 Thermal Printer
NECSITO LOS DRIVERS PARA EL PRINTER NCR 7167, GRACIAS
http://www.fixya.com/support/r1468656-free_printer_drivers_lost_driver
Jun 21, 2009 | NCR 7167 Thermal Printer
Cash Draw issues
It should be the RJ-11 Connection on your 7167 System Board... Most likely needs just a good cleaning, or needs to be resoldered <-- NCR Technician Now Sales Rep...
2425 Enterprise Dr.
#200
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR,IBM... We also offer structured cabling as well as Video SurveillanceEquipment.
Aug 16, 2008 | NCR 7167 Thermal Printer
Any downlaodable cd?
plz check the manufacture website for drivers
Aug 13, 2008 | NCR 7167 Thermal Printer
Running NCR on canon IR 8500
Hello Visionsp, NCR paper is special in so many ways (uhg).First of all is is typically thinner than regular 20# bond paper. Second,each sheet is chemically "married" to the other as there are ink beads on the back of one sheet that are activated by the unique beads on the face of the second sheet so to some degree they are manufactured to be mated together. So unless your paper feed system is @100% then the sheets (2 or 3 sheet NCR) are more difficult to seperate and are inclined to feed two sheets at once. THE BIGGIE is this. Consider the fact that in order to produce the carbon copy image that is being transferred from the top sheet to the pages below it requires pressure from from the pen. Your IR 8500 (and all modern copiers) has a section of the copier called the fuser.It uses extreme heat and pressure to bond the powdered carbon based toner to the paper by passing your normal copies between two heated and tightly gripped rollers, kinda like using an iron with extreme force. When the NCR paper passes through the fuser the exteme heat and "pressure" break the chemical ink beads on the NCR paper and begin to leave a layer of the very same chemical ink on the rollers as they pass thru.But instead of only trace amounts of carbon copy image (as would be reproduced by a customers signature on to the next sheet ) the entire NCR sheet is being heated and mashed and a large amount of the chemical ink is being activated rightat the point of maximum heat and pressure. Not only is this sticky as *&%$ ,but it leaves a residue on the fuser rollers (since there is no paper to transfer the beads to) and the rollers build up with ......basically ink. So at some point the copies going through the fuser will rather wrap around the rollers or cause "accordion" jams because the telon coated rollers are no longer coated with non stick teflon but are coated with tacky gunk. The only workaround for this is to run small runs of the NCR paper at a time, then run regular white paper for a while which will remove the buildup and then another quick run of NCR and so on. I have worked on Canon,Toshiba,Ricoh,Savin and Kodak copiers.The results are the same.NCR paper is not designed for regular copiers as they all use the same type fuser system. A press or a RISOGRAGH are the only reliable systems to run NCR paper. I wish I had better news.NOTE: even the workaround I have provided,which can work, does not eliminate the possibility of ruining the fuser rollers beyond repair. good Luck...............SPINAL
Feb 09, 2008 | Office Equipment & Supplies
Thermal print head repair
I have an Evolis Pebble 4 Printer. We use this machine to Print at leat 2000 cards a day.
We would like to know from where OEM Printheads for this machine can be procured as the
cost of the originals is too hgh?
Apr 18, 2007 | NCR 7167 Thermal Printer
NCR 7167 Thermal Printer Logo
207 people viewed this question
Top NCR Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NCR Office Equipment and Supply Expert? Answer questions, earn points and help others
