Question about Toshiba 50H81 50" Rear Projection Television
Lightning strikes on screen and takes awhile to warm up then fine
Hey hows it going im having a problem with my tv...the picture was scrambled in morning and taking awhile to warm up then fine,but it has little lightning bolts every now and then ,,,is this an easy fix??? I really like the tv,,,,and recently it is getting worse please help,,,B.
  • 62 Answers
Sorry its not an easy fix at all. im sorry wat you have to hear, but do you have kids? if so, they probably bumped into or hit the screen. that would result in permantly damaging the screen
Posted on Apr 01, 2009
Take computer out of car bring inside house connect next day in cold morning car turns on
It would shure help if you had the year end the model of the car on hear,Like it is a little bit hard to belive that your a tech, How much have all vehicles changed in the 18 years that you been a tech.?
Oct 23, 2012 | Cars & Trucks
My TV pictures scrambles after warming up
Check and replace all the electrolytic capacitors.
Aug 28, 2012 | Televison & Video
I have a Mitsubishi VS-55707 and I have a couple of problems. first it takes 5-10 minutes to warm up (scrambled picture) after that it works fine, but its getting longer to warm up. Second every once in...
i had the same problem. im sorry to say that you are out of luck and you tv is on the way out. i had the same problem and spend $100's of dollars to have people come and try and fix it to no luck. sorry
May 23, 2010 | Mitsubishi VS-55707 TV
When you first turn it on, the picture is scrambled. takes fifteen to twenty minutes to warm up and get a good picture. Once and awhile after the picture warms up it will blink like the picture is going...
It seems that your unit has some sort of Thermal fault, either in the main circuitry or the Power Supply Unit, PSU. In all probability it WILL get worse and fail completely.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Televison & Video
First thing in the (cold) mornings heater wont work. water gauge flux's up and down weird . then about 20 mins into driving its warms up
Your engine coolant is what your heater gets the heat from. You need to start your car and let it warm up for awhile before any heat will come. This is how most cars heaters work. Yours sounds like it is working fine; most cars take a little while to warm up.
Hope this helps!
Dec 07, 2009 | 1992 Toyota Paseo
Compressor makes a funny humming noise and frigerator gets warm , if you tap the compressor it works fine for awhile, but after awhile I get the annoying humming sound again and the temp in the...
your loosing your relay or overload,,, tapping works hey...... like and old chevy starter
anyway
look at the compressor you will see the parts im tlking about
relay and overload
pull these off and ohm them out
sounds like thay are going bad
very easy reapir go to
www.appliancepartspros.com
jujst type in your model numnber
and seacrch the compressore=
compartment
order and replace you should be fine
Oct 24, 2009 | Refrigerators
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
TV picture scrambled and getting worse
This can be a fault in the tuner, IF, or primary part of the video processing. With age and use some of the parts, and especialy capacitors, in these sets can become thermo sensitive and unstable.
To service these types of faults can be very time consuming. On top of this would be the cost of the parts.
Considering the age and type of set that you have, I would suggest that it is time to be looking for a new set.
Jerry G.
Apr 21, 2008 | Toshiba 50H82 50" Rear Projection...
Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Mar 18, 2007 | Toshiba TP50H50 50" Rear Projection...
Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
Nov 21, 2006 | Samsung HCN473W 47" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
