Question about Kenmore Refrigerators
Remove cover on control damper for kenmore mod.#596.79272993
How to remove cover
3 Suggested Answers
  • 9 Answers
SOURCE: the damper control is not working but I cant get to remove the cover in order to replace it
against the back panel there are 2 finger holes on that cover, at the same time stick your fingers in the holes and pull down to avoid the locks and then slide the cover out.
Posted on Jul 02, 2009
allbrands
  • 600 Answers
SOURCE: How do I remover the
Hello, Thank You for using FixYa. I will be helping you today. The vent or grille part just pops out and behind it are two screws remove the two screws now you can remove the cover. The damper is just held on by a clip an each side. Here is the part Control, Damper Part #: 67003903
Thank You and please rate my answer if it was helpful..
Posted on Jun 21, 2011
Where is damper door in a kenmore refrigerator model #9510681 side by side
If you can't see the damper door, it is most probably shut, possibly frozen or not working. Top of middle section, allows airflow from freezer to fridge part. Switch thermostat off, wait 20 mins, switch back on. If damper doesn't open, check stat and damper motor.
May 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
How to access/replace the vent selector(defroster) ?
buy one
and install it.
it has clamps remove them or unsnap them and .....
access? its in the dash.
the FSM covers all HVAC work , you can get that and read it
or hope that ALLDATA.com covers R&R for the cables.
but will cover access. (huge job on some cars)
working on the dash with out and FSM invites more broken parts.
plastics.
hidden screws and such , and how to get to them are covered in the book.
here is the control panel, pasted
Removal & Installation
  1. Remove the upper console panel.
  2. Remove the instrument cluster finish panel
  3. Release the 2 fitting claws and pull out the heater control assembly.
  4. Using a screwdriver, open the claw of the cable clamp and disconnect the defroster damper control cable. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  5. Using a screwdriver, open the claw of the cable clamp and disconnect the air mix damper control cable.
  6. Disconnect the connector, remove the heater control assembly. 42050_coro_g0008.gif Removal and installation of the control panel
To install:
  1. Install the inner cable end of the air mix damper control cable to the heater control lever.
  2. Install the outer cable of the air mix damper control cable to the cable clamp. NOTE Be careful not to bend the cable wire. If the cable wire bends, the heater control assembly operationally becomes worse.
  3. Operating the heater control knob and check that it properly stops at both ends of MAX. COOL and MAX. HOT and no recoil is identified.
  4. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  5. Install the inner cable end of the defroster damper control cable to the heater control lever.
  6. Install the outer cable of the defroster damper control cable to the cable clamp.
  7. Operating the heater control knob and check that it properly stops at both ends of FACE and DEF and no recoil is identified.
  8. Check that the outer cable should not be disengaged (moved) from the heater control assembly when the cable is pulled.
  9. Connect the connector, install the heater control assembly.
  10. Install the instrument cluster finish panel
  11. Install the upper console panel.
Dec 13, 2013 | 2005 Toyota Corolla
I have a kenmore side by side. FF side too cold. Replaced t-stat and defrost timer. All settings and air flow set right. FF still too cold. T-stat set all the way down . Should be at 3 or 4
You need to provide a model number in order to look over the parts list and see what type of auto damper your model has. There are ways to test an auto damper to see if it opens and close properly. An auto damper can be electrical or mechanical. Kenmore model numbers look like this example=> 321.2345789 and can be found artound the fresh food compartment door frame.
1 Turn power off to refrigerator.
2 Open the fresh food sections door and remove all items on top shelf.
3 Adjust the fresh food control to its coldest position.
4 Remove the light shield by pulling down on the back corners of the cover and then slide the cover forward.
5 Remove the edge sealing device, radiant shield supporting screws at the back bottom center of the control housing mounting screw at back, bottom center of the control housing. Slide the control housing to the right and lower the housing.
6 Disconnect the temperature control housing from electric quick disconnect.
7 Remove the temperature control housing from the refrigerator and then place on a
flat work surface.
8 Remove the auto damper control rod retainer, control rod and the slide control
gear from the auto damper control.
9 Now turn the control housing over.
10 Remove the two auto damper mounting screws, then remove the auto damper from the control housing.
11 Mark the auto damper rod about 1/4 in. from and away from the housing.
12 Uncoil the auto damper capillary tube at about 4 in.'s
13 Submerge into a glass of ice (not water). then watch for door to move to the closed
position.
14 Remove from ice and warm capillary tube with your hand. Then watch door for an opposite reaction.
15 If no movement is detected, replace the control. 61005971 Damper Control Assembly
The above is only a demostration of how to test a refrigerator with an auto that uses a capillary tube to open and close the damper. Your refrigerator will need to be identified by the correct model number to let you know what type of auto damper your model has, Post your model number and I will tell you what you will need to test yours, Thanks Sea Breeze
Apr 12, 2013 | Refrigerators
How to install a damper on a Frigidaire side by side
Installing the new damper control takes just minutes. The replacement damper control comes with a foam mounting gasket. Remove the paper backing from one side of the gasket to expose the adhesive; press the gasket to the back of the damper control. Now that the gasket is mounted to the damper control, you can mount the damper control to the freezer wall. Peel the paper backing off the other side of the gasket and press the damper control to the mounting area. The wiring harness and thermistor attach to the right side and bottom of the component, respectively. Replace the damper control cover and reinstall the removed mounting screws.
Mercedes wheels
May 31, 2012 | Frigidaire Refrigerators
How do I remover the damper cover from my French door, bottom freezer Maytag refrigerator? The damper has gone out twice. It takes the repairman exactly 30 seconds to take off the cover and change the...
Jun 21, 2011 | Maytag MFD2560HES Bottom Freezer French...
I have an Amana ARB2217C bottom freezer with working lights, fan, and freezer. But the refrigerator doesn't seem to want to cool. I think it stopped a couple of days ago.I've turned the thermostat from...
The problem has to be in the damper control inside the refrigerator section.
Disconnect the refrigerator from power and remove the food from the top shelf. The damper control is in the box near the top of the refrigerator section behind the temperature control knob.
Remove the knob and cover until you can access the damper control. You can prop the damper control open with a pencil or something to make the refrigerator work until you get a part if you need to. Here is the part you need.
Feb 19, 2011 | Amana ARB2217C Bottom Freezer Refrigerator
I have a Kenmore refrigerator/freezer model # 596.65232401, this is the one with the freezer on the bottom and refrigerator on top. The freezer works fine, the refrigerator was not cooling, I removed the...
What you didnt state was whether you had cold air blowing when the damper opened up. If you did, then the problem will be with the damper assembly itself, or the control board, which is what you would adjust to change temperatures. This microswitch you mentioned, was this on the control board? then the control board is the problem. If you did something with the damper assembly, then that might be the problem.
If you dont have any cold air blowing when you opened the damper door, then airflow is your issue, and you will have to include more symptoms for a refrigerator repair diagnosis.
Nov 27, 2010 | Kenmore Refrigerators
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Er dh code error on Kenmore elite trio
Jul 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The damper control is not working but I cant get to remove the cover in order to replace it
May 07, 2009 | Jenn-Air JCB2389G Stainless Steel Side by...
Refrigerators Logo
569 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
