Question about Kenmore Microwave Ovens
Kenmore elite ultrawave microhood combination error code F9
I have a kenmore elite ultrawave microhood combination number 721.64689 that gives us an error code F9 when we run it. every few seconds it sounds funny, and things do not get warm in it. but the glide tray moves back and forth as normal.
sears will not give us any help at all with this code. can you help us?? we don't want to send to repair i it is not worth fixing. it is 3 years old.
  • donald561 Jan 06, 2009
    my nuke: sears 721.63682300.. mfg date: 2/03.. it'll run for 30 seconds without heating, then shut down , then shows F9... lites, vent and kitchen timer work fine... any help out there??? thanx, don
  • Kenmore Master
  • 8,872 Answers
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 24, 2008
  • Lucia Tam Sep 23, 2013
    Thanks for the information, but it is still not clear how to fix it. How do you access the hidden manual?
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
Dec 24, 2012 | Kenmore Elite Over The Range Microhood...
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
F-9 Error on Kenmore Ultrawave Microwave Model 721.64682300
From everything I have read it is a 1100w inverter, I am having the same problem.
Mar 12, 2009 | Kenmore Microwave Ovens
F9 Error
You can find exploded views and order parts by entering your model number at the Sears parts site.
Dec 06, 2008 | Microwave Ovens
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Note: This 'technology' may come in other flavors as well
Jan 19, 2008 | Kenmore 62622 Microwave Oven
Kenmore microhood model 721.80833500
our tray that goes around and back and forth jumps the tracks and stops and turns the other way I can put it back on track before it makes a round it jumps the tracks again and starts going the other way is there a part that need replaced
Jan 13, 2008 | Kenmore 80809 Microwave Oven
Microhood turntable not working
You can find an exploded view of your microwave at http://www3.sears.com (yes, the 3 is there). Ref # 3009 on the drawing is the turntable motor. I would grab it by the shaft and gently try to turn it. If it's locked up or grinding, that's a sign it's bad. It runs $24.49 plus shipping: Part Description: Quantity: Part Number: Model Number: Price: TT MOTOR 6549W1S013D 721.64663300 $ 24.49 $ 24.49 Be sure to unplug the oven before you work on it. Hope this helps!
Dec 01, 2006 | Kenmore 63763 Microwave Oven
Stainless Steel Kenmore Elite 36 in. 2.0 cu. ft. Microhood Combination Model 63763
Generally the F9 code indicates a problem with the door latch (usually upper) or with the control board. You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble. BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly). Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further. It may be corrupted ROM in the control unit. But let us know what you find out. - online they call me "William E. Miller, AS-EET"
Oct 15, 2006 | Kenmore 63763 Microwave Oven
Microwave Ovens Logo
1,191 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
