I have a large house with three areas, three areas are cast skirting radiators controled with indivisual room stats controling three motorised valves i have fitted a combi boiler but i want to keep the skirting rads would you supplyme with a wiring schematic for this unusual heating system thanks kevin
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Hey kevin ,type it up on the internet ,find the manufacture name for the valves or the thermostat.!
Posted on Aug 22, 2008
I have hot water but can't get heating to come on
you don't say what type of boiler you have, but as a guide...
Three port valve may not be operating.
Heating Pump may not be operating.
Room thermostat incorrectly set or not working.
Start with the room stat as it controls the valve and the pump..
More information about your system is needed to help you further..
Apr 17, 2017 | Water Water Heaters
Where is the location of the thermostat 2002 pontiact gran prix
engine? (or climate control Hvac stat)?
engine, see the radiator one large hose goes directly to the thermastat housing.
Jun 21, 2014 | 2007 Kia Sportage 4x4 V6
Make : Weil-McLain Model : CG-5-SPDN Series 12 I have the above mentioned boiler which is located on the 1st level of a three story one family house, the area where the boiler is located is insulated.
You don't have an optimum distribution of steam in your house. Try closing a little bit the valves supplying the heaters in the lower floors. Close a little bit more until you get the desired balance.
Nov 06, 2012 | Heating & Cooling
No hot rads down stairs boiler comes on 3 miniutes then of again
Hello
By your post im guessing you have a 2 story house.
Have a look at the boiler,water pressure guage.Should be between 12 and 15 psi 140 to180.f when running.
If its above or close to 30 psi the relief valve will open to let off the pressure,we do not want this to happen normally.
If you have high water pressure at the boiler you will need to go to the highest radiator or any one on the second floor and open the bleeder.Looks like this
http://www.ourfixerupper.com/wp-content/uploads/2007/11/cast-iron-radiator-02.jpg
Carefully open it slow into a bucket,let air out until you get a steady stream of water.Do this to all of the radiators,idealy using a bleeder key or needle nose pliers.This may take some time.
Once we can assume all the air is out,check your water pressure again should be 15 to 20 psi.If you have no pressure then your auto fill valve is bad.If you have 15 to 20 then proceed.
Raise the temp of the t stat to start the boiler.6 degrees above whatever the room temp is.
If you still are having problems your t stat may be faulty.If your boiler is at 15 to 20 psi 140 to 180.f and it still shuts down after 3 min your return pump may be bad.
Hope this is helpfull
Dec 21, 2010 | Heating & Cooling
My Honeywell ST 6400C won't heat the hot water the light comes on but pump doesn't run or boiler fire. But does work on C/Heating.I can get hot water only by running the C/H and manually opening the hot...
it sounds like the motor in the motorised valve is not working on some models you can just change the head /motor , check cylinderstat (hot water stat) is working
Dec 14, 2010 | Honeywell Heating & Cooling
No hot water in sink and shower
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
May 04, 2010 | Rinnai Digital Remote Water Heater Control...
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Where is the thermostat located on a 1992 toyota camry v6?
The thermostat housing is on the passenger side of the engine, under the alternator area. You cannot see it with the alternator installed. Not easy to change, but, if you do, buy a Toyota thermostat. The factory 'stats have an air-purge valve, and it is very important. The aftermarket 'stats do not have this valve. Note that when you replace the 'stat the air purge valve should be at the top of the hole in the housing (pointing straight up).
Sep 07, 2008 | 1992 Toyota Camry V6
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
