Question about Dometic Rooftop RV Air Conditioner
1998 Sonnybrook travel trailer
My AC works greak as long as it's not in auto. With the fan set to Low, Med, or High, the Ac cycles on and off like it's suppose to. When I put it in Auto, the AC with satisfy the thermostat and shut off. When it starts back up, the compressor will come on but the fan will not. I have to switch it back to the manual mode to get the fan to start back up.
I am the second owner, bu the first owner told me about the problem. I can only assume that it worked right in the past. I keep the trailer at the beach and will be going there this week-end. I will get the model numbers and send them to you.
Posted on Aug 26, 2008
  • Dometic Master
  • 6,674 Answers
Did it just start to do this, or has it always been that way? Are you original owner? Did it work fine before? Make, model# of AC unit & thermostat would be of help too.
Posted on Aug 25, 2008
2008 Honda Odyssey AC fan works on low and med speeds but no high speed blower
There should be a high speed blower relay that bypasses the resistor for slower speeds.
Check with an auto parts store or the dealer.
Jun 23, 2012 | 2008 Honda Odyssey EX-L
Ac fan will not run on high setting , manual or auto . when unit calls for high setting fan shuts down . Compressor continues to run and trips breaker in trailer . Someone thinks it may be the motor, but...
Most probably its weak motor.When the motor gets weak it trips/ stops on high setting.On high setting motor needs more power to run the fan.Try lubricate the motor .You may need a few drops of oil on the fan motor bearings. As they get older they get dry and gunked up. If you can see the bearings a few drops of oil may help. --------- Because the fan operates on medium and high, so loose wire or faulty fan switch is very rare to cause this problem.-------- As per the problem , it requires motor to be replaced.--------- This will help.Thanks.Helpmech.
Jul 29, 2011 | Dometic Rooftop RV Air Conditioner
I have a problem with the FAN setting on my AC. It has 3 settings -Auto-High-Low. It cycles thru all 3 settings and keeps beeping as it cycles thru - its doing this almost continuisly every so often it...
The thermo stat its self no good if this is a house issue. Had the same problem. Went to lowes and got a new one. The old one pulls out and the new goes in its place. No wire touching. If u can find a close match. If its a car a/c good luck never even seen a auto feature in a car. Only high med low.
Jun 24, 2011 | Heating & Cooling
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Have a 2003 Jeep Wrangler, Rubicon and the hear/AC blower fan only comes on in the high position. The other setting low, med and med/high the blower will not come on. Is this the controller it self?...
The problem usually stems with the blower motor resistor,high speed by-passes it and there-fore the controller is sending power but the resistor has gone open and the speeds can't be regulated.
Feb 08, 2010 | 2003 Jeep Wrangler
Ac fan will not work on low or med only on
It may well be the fan switch is defective
Jul 27, 2009 | Heating & Cooling
1998 Astro Van Heater AC Blower only works on medium & Low
Yes, in high it bypasses the resistor and uses a high blower relay. But I think on 1998 Astro the High relay and the resistor are built together. It should be mounted in the blower box real close to the blower motor.
Mar 09, 2009 | 1998 Chevrolet Astro
Dometic Rooftop RV Air Conditioner Logo
121 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
