Carlton ac 9000m air conditioner
Hi i was given this ac unit for my garden office but the im not sure how to use correctly i have installed the outlry water tube so it drains all the time and the outlet hose but i need the instrustion manual for it ? as i have no idea really what the thermostat does or what its for or how the unit works i have uploaded a photo of the control panel perhaps somone can enlighten me
  • 154christine Aug 23, 2008
    hi thanks but there is no manufactors spec on the internet i have been looking for weeks that was my first port of call ,so that why i thought i would try somewhere that might no seems not ?
    but thanks all the same
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Hey, give it back! or check the manufacture spec on the internet.
Posted on Aug 23, 2008
Plugs on Carrier yc273d air conditioner
You probably have a 230 volt AC that uses a different plug. If you insist on using unit there you will need an electrician to run the correct wiring and install the correct female for your unit to operate.
Jul 13, 2015 | Carrier Heating & Cooling
Took it out of Box, Pluged it in to First Make Sure it Worked and It VIBRATES So Bad Im Scared to Install it.....What should I do?
If you think something is wrong with the air conditioner, you take it back to the store. No a new air conditioner should not vibrate violently. They are pretty quite, so take it back to the store, and exchange it for another one.
Apr 07, 2014 | Frigidaire 5000-BTU Window Room Air...
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
When i run the ac it leaks on the floor from the inside n i dont know what to do about this problem.
All portable or window ac units are mounted or standing with the back lower housing at a slope
so that the condensed water buildup from the evaporator can drain into a tray or thru a tube out
the back of the unit, depending on what kind of unit you have you may have to take it apart and
make sure the drain for the condensed water is not blocked. some times these units are not
installed correctly, they will not drain properly and standing water with time will turn to rust and
clog up the tube where it needs to flow from the ac unit. good luck!
Jul 31, 2011 | Windchaser PACR10000 Portable Air...
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
I was given a Haier ac. I installed the ac. It was running fine. I left the air on today and it was 94 degrees outside. The ac was on all day. I notice it was getting warmer in my room not cooler. I...
clean the filters and clean the condesor coil. You have an air flow problem or it may be low on charge which I doubt because these units are critically charged units. I would clean the coils and filters first.
Jun 21, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Window air conditioner
Hi, yes you can put a window unit through a wall. Just make sure that the condensation will drain from the indoor coil to the out side which it should do on its own design. Also, make sure that the condenser coil at the rear of the unit is all out side. You will have no problems at all. You can use 2- peices of small chain at each corner and use small lag bolts to secure it to the wall. Looks better then to build a frame to set it on for support. Yes, they are made to install in either place.
Best of Luck,
Shastalaker7
Jun 06, 2010 | Heating & Cooling
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
What type of freon my ac uses
R-22, if it were R-410A then it would have a pink sticker on it near the service ports. You would know for sure.
Mar 24, 2009 | Weather King 12AJA4801AH Air Conditioner
Hose required for Amcor 12000!
hi,
looking at the standalone a/c the vet has in their office where I live, I noticed what they are using, its a dishwasher drain hose and you can get them at any hardware store, you will need a hose clamp for that also, the hardware store employee should be able to get the right clamp for you. Im in the united states but Im pretty sure dishwasher drain hoses are universal.
good luck
J
Aug 06, 2008 | Amcor 12000 Air Conditioner
Heating & Cooling Logo
769 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
