Question about Konica Minolta Office Equipment & Supplies
Konica Minolta Copiers
I was recently given a Konica Minolta 7035 copier that did not work. when it is turned on, it says "copier is warming up" then it displays a screen that says to call service center with error code F-26-1. Does anyone know what this means?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Konica Minolta Master
  • 1,362 Answers
F26 Toner density adjustment problem. This means machine is undertoned. To repair, replace developer and enter "47" mode. Press 51. Press print. Allow the machine to cycle until it stops. Some feel that you should disconnect the toner motor first. This ??? ?????? happens probably because either machine wasn't set up properly, or the customer kept on using the machine with the toner light on.
Posted on Aug 25, 2008
I have a konica 7020 machine, the first copy comes with horizontal black lines but not the others (when copying e.g more than one copy)
1 look to the drum surface for scratch if their is replaced it. 2 the write unit might already defective. Damage drum will cause sparks to charging unit and Horizontal lines produce.
Dec 02, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
How i can adjust the position of the Touch Panel display konica 7020
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
Oct 06, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Code F- 43-1, always pop out whenever i open the power
Your Exposure lamp (Halogen lamp) L1 is busted or the Optic fuse F1 is open---continuity test use tester. Replace it.
Sep 26, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
What does code F52 mean
It seems that your drum is asking for a new one.
Jul 24, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
WHERE CAN I FIND A USAGE REPORT?
press the star button to print that info press print on that page
May 28, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Hooper assembly is not working in coping but working in 47 mode
remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
Error code F-46-11 in my photocopier konica minolta 7035
A 46-11 code indicates a communication failure between the A/D converter board and the main control board. Likely a bad or poorly seated ribbon cable. Try to reset the machine by turning off the main power switch on the side of the machine for 10 seconds and re-powering up. If the problem persists you will need to call a technician.
Feb 04, 2009 | Konica Minolta DiALTA Di200 Copier
159 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
