Question about Hotpoint VBXR1090D Top Load Washer
Washing machine it try's to spin but then it stops and wont spin
  • 1 more comment
  • Anonymous Dec 26, 2008
    hotpoint washing machin wont spin
  • sazzajayne Jan 01, 2009
    i have a bosch washer and it makes a strange noise, and wont rinse or spin, it seems to work through the wash though.
  • Himankshi Chaudhary May 11, 2010
    does the water drain out without spinning.?
    Novelist:
  • 166 Answers
  • If it is neither draining noe spinning check If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • Posted on Nov 12, 2008
    • 121 Answers
    SOURCE: My washing machine has stopped spinning.
    it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
    Posted on Mar 03, 2008
    SOURCE: my washing machine wont spin
    i have a roper washing machine that is not spinning all the water out any clue to the problem
    Posted on Nov 03, 2008
    barkencoa
    • 3463 Answers
    SOURCE: washing machine wont drain keeps bleeping ERR2
    It will not spin with water in.
    See if you can locate a filter, and clean same.
    Posted on Jan 19, 2010
    • 942 Answers
    SOURCE: washing machine drains, wont spin, making clicking
    If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
    Posted on Jan 30, 2010
    SOURCE: Bosch wfd2473 washing machine wont drain or spin
    I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
    Posted on Feb 17, 2010
    Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
    Problems with a washing machine not spinning or not draining are often interrelated..
    If you are having a problem with your top load washer then check out thistip...
    Washing Machine does not Pump or Spin
    If you are having problems with your front load washing machine then checkoutthis tip...
    Front Load Washing machine not draining and or not spinning
    heatman101
    Apr 21, 2011 | GE Washing Machines
    Washing machine wont drain keeps bleeping ERR2
    Jan 19, 2010 | Haier Washing Machines
    Wont spin
    the machine will only drain after the rinses and give it three minutes to reach a pressure setting if this pressure setting is not met within the three minutes,the machine will stop, this sounds like the drain might be slightly blocked try there first, and then the drain pump and sump of the machine.
    Jul 30, 2009 | Washing Machines
    My washer wont spin
    sounds like a bad lid switch ,check that-mike
    Jun 03, 2009 | Washing Machines
    Washing machine wont spin the water out.
    IT IS VERY POSSIBLE THAT YOU HAVE A BAD OUT OF BALANCE SWITCH. THE MACHINE WILL NOT GO INTO A HIGH SPEED SPIN IF THE SWITCH IS BAD.
    Mar 18, 2009 | Fisher Paykel EcoSmart GWL15
    Washing machine does not spin
    Nexxt 100 Series WFMC1001UC Front Load Washer This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Feb 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
    Wont Spin
    Hi Vixxy, Which lights flash when you hear the beeping?
    Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
    Hotpoint VBXR1090D Top Load Washer Logo
    94 people viewed this question
    Top Hotpoint Washing Machines Experts
    vince
    Todd Arndt
    Todd Arndt
    puggy666
    Level 1 Expert
    Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
