Contributor
- Posted on Jun 25, 2011
Re: My samsung monte slide makes a beep when i send a...
Choose settings for profiles
Find "Profiles"
- Press Menu.
- Scroll to Settings and press the Navigation key.
- Scroll to Profiles and press the Navigation key.
Select profile
- Highlight the required profile and press Options.
- Scroll to Edit and press the Navigation key.
Select settings for incoming calls
- Highlight one of the following options:
- Call alert type, go to 3a.
- Call ringtone, go to 3b.
- Message alert type, go to 3c.
- Message alert tone, go to 3d.
- Keypad tone, go to 3e.
- Volume, go to 3f.
- Press the Navigation key.
3a
"Call alert type"
- Highlight the required incoming call alert and press the Navigation key.
3b
"Call ringtone"
- Highlight one of the following folders:
- Default melodies
- Sounds
- Music
- If you select Default melodies:
- Highlight the required ring tone and press the Navigation key.
- If you select Sounds or Music:
- If required, highlight a folder and press the Navigation key.
- Highlight the required ring tone and press Select.
3c
"Message alert type"
- Highlight the required message alert and press the Navigation key.
3d
"Message alert tone"
- Highlight the required message tone and press the Navigation key.
3e
"Keypad tone"
- Highlight Mute or the required key sound and press the Navigation key.
3f
"Volume"
- Highlight the required category and press Navigation key right or Navigation key left to select the required volume.
- Press the Navigation key to save.
Exit
- Press Disconnect to return to stand-by mode.
