Question about Orion1934 19" TV
Orion 1934 19 " tv
Where is the fuse located?
  • anglersquest Aug 23, 2008
    Thank You! Shuttle83, I found the fuse and it was good...dont know the reason that the TV wont power on. The house was struck by lightening and alot of 110 volt items dont work now.
  • Donna Phillips
    Donna Phillips Sep 12, 2008
    I have two Orion TV1929B televisions. One seems to be older than the other. the newer one does not respond to the remote and even a new remote made no difference
    The older one is very hard to turn on and off. But once you get it on it has a better picture. Because the older one is so hard to turn on I am using the newer one. I found a fuse on the floor where the TV sits. How can I find where it goes? Can I assume it goes to the one that is NOT plugged in?
    Thanks
    Genius:
  • 1,139 Answers
Hello anglersquest,
It is usually located near the power supply section. unplug the TV, open the back of the TV and look for a small glass cylinder with two metallic ends. This will be the fuse, now to check it do a visual inspection and you should see a clear cylinder with no internal dark smuges (good) has smudges (bad). Then if you have an ohmmeter set it to the 1xR setting and measure the fuse ends it should read 0 ohms if the fuse is good and no reading if the fuse is bad.
I hope this helps
Thank you,
Shuttle83
Posted on Aug 23, 2008
  • Henry McKelvey
    Henry McKelvey Aug 25, 2008
    Hello anglersquest,
    Since lightning is a common problem I would suggest that you check the following components. The voltage regulator in the power supply, ah first I must ask, was the TV in a surge protector? Because I would expect for the fuse to actually be bad in this case, however check your surge protector first. The check the voltage regulator. Then possible the power FET (if used) in the switching power supply. The check the IHVT (Integrated High Voltage Transformer) and the HOT (Horizontal Output Transistor for possible shorts to ground.
    or you can take it to your local TV repair shop.
    Might I suggest if you don't want to repair the set that you could possibly take it to your local Vocational High School as a donation.
    I hope this helps,
    Thank you,
    Shuttle83
Where is the fuse located on a M68LWF088X50 toshiba 27D46 27" tv?
If you remove the back cover of your tv try to follow the ac cord it will direct you to the fuse it is glass type. The ac cord is connected to the pcb just follow the line and you will find the fuse, but be sure to unplug the unit before removing the back cover of your unit, good day and best regards.
Aug 23, 2011 | Orion1934 19" TV
Do orion sub have fuses?
No, subwoofers are not fused, however, amps are. If you're having a power supply issue you might check the fuse located on the amp itself, or any inline fuses that may be installed on the wire powering your amp. Inline fuses are generally mounted right next, or sometimes, attached directly to the car battery.
Jul 04, 2011 | Orion HCCA 10.2 Car Subwoofer
Have 8 yr old Orion tv-new remote control for satilite Dish network wont turn tv on--need to know what orion tv codes are.we tried everything tech said to do ,need to know what orion tv codes are..lost the...
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 11, 2010 | Orion1934 19" TV
I have an Orion TV Mod TV1933b
Unfortunately, with most TVs this function is located only on the remote. If you could do it without the remote there would be a button on the panel of the TV labeled accordingly.
To purchase a replacement remote (a universal remote won't work with that model TV) call Fox International at 800-321-6993. They are the largest Orion parts distributor that I know. Orion doesn't sell parts directly to the public.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 11, 2009 | Orion1934 19" TV
Orion tv codes
try these codes for the orion tv:0121,0135 or 0035. good luck
Nov 03, 2007 | Orion1934 19" TV
Orion 1934A
You can check for fuse and fusible resistor, also horizontal output maybe shorted
Aug 30, 2007 | Orion1934 19" TV
Orion FTDV 2004 Dead Set
Question, when I clicked on this I clicked on a problem for a Sony KV27S10 but your text say's Orion, is it a Sony or a Orion?
Aug 18, 2007 | Sony KV-27S10 27" TV
Orion TV 1934
You might try substituting a new fuse. Be sure the replacement has the same rating. You may have a short in your power supply and depending on the type of supply the supply may not start up if it has overload protection. Stargazer
Aug 05, 2007 | Orion1934 19" TV
Orion1934 19" TV Logo
164 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
