Question about Initial HDTV-322 32 in. LCD Television
Remote control for the most part the remote control is working properly. however when i change the channel up or down using the arrow keys the tv acts like the channel is changing (by going blank for a split second) but then returns to the same channel. it wont allow me to scroll up or down through the channels
  • Initial Master
  • 5,568 Answers
Is this a new condition?
Or has it operated differently in the past?
If you are connected to any kind of box (satellite for example), there is only one channel that the TV sees; usually 3 or 4.
The channel changes are limited to the box.
Posted on Aug 22, 2008
I changed my tv from cable to an indoor antenna however I cannot get it back to set up to change it over to antenna or air. Help1
Do you mean the Curtis LED1930A 19" TV? If so, first check that the source is set to TV. Use the Source button on the TV (just below the power button) or the remote (to the right of the 0). You can use the up/down arrow keys to change lines in the Input list. Press Enter to confirm the choice if you are using the remote.
Next press Menu on the TV (the third button from the top) or remote (to the left of the 0). Use the left/right buttons to navigate to the Channel heading (the third item from the left). Use the Source key (on the TV) or press Enter on the remote to enter the menu. Use the up/down arrows to highlight Signal Type. Press Enter (or Source) and then use the left/right arrows to get Air. Press Enter to confirm the setting. Now you should be able to highlight Auto Channel Search and search for your OTA channels.
This is shown in the manual. The manual is available from Amazon here: .
I hope this helps.
(The Channel menu is not accessible when the input is not set to TV.)
Mar 29, 2017 | Televison & Video
On mx900 genesis universal remote the up down arrows to change channels will not work - cannot get guide to display -cannot change channels using#key pad - volume up down work fine suggestions?
Incorrect code. Try different programming codes for one that operates your TV correctly. Note not all universal remotes will work all features of a tv. Sometimes all you can get (especially on lower end remotes) is power and volume
Nov 01, 2016 | Televison & Video
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
Connecting direct tv todvr to a2005 20 inchrca sdtv channel code
1. Using Programming Codes
Find the TV code for your TV in the list from the Platinum Remote Control User's Guide (See References). For example, if you have a Kenwood TV, the three possible codes to try are 506, 573 and 712.
Press the "TV" button on the remote. Hold down the button until the "Sat," "VCR" and "Aux" buttons light up. Release the "TV" button and it will be flashing.
Enter the first code using the keypad. If you want the remote to control all functions on the TV, enter the code and press the # key. The "TV" button will flash three times.
Press the power button to turn off the TV and turn it back on again. If the code was correct, the TV will turn off and on. If the TV doesn't power down or back on, follow Step 6.
Try the next code from the list. Follow Steps 2 through 4 using each code until one turns off the TV.
2. Programming Without Codes
Press and release the "Power" button on the remote.
Press the arrow up key and stop. If the TV doesn't turn off, press the arrow up key again. Continue pressing the arrow up key until the TV turns off. Do not go fast when moving through the codes or you could miss the correct code. Press the arrow key and wait at least 20 seconds to see if the code works before pressing the arrow key again.
Press the # key on the remote when the TV turns off to lock in the code.
Jan 08, 2013 | RCA Televison & Video
Can not change channels
problem with universals is they do not if program have all the key features needed--try for a original remote.
Dec 03, 2012 | RCA Universal Remote Control
Lost remote control how to i move the arrows ithout control
Normally the CHANNEL UP / DOWN and the VOLUME UP / DOWN buttons on the front of the TV set itself will function like the arrow keys on the remote when you are navigating the TV's ONSCREEN MENU.
Otherwise, you can always go out and buy a universal replacement remote control and program it for use with your TV.
I hope that helps, good luck and take care.
Aug 13, 2011 | Televison & Video
I have a Sanyo tv ( model #DS19330 ) and using a Sony remote to operate it. I am trying to restore channels 14-69 by scrolling through the channels with the remote. I can punch all channels in by...
It sounds like that the TV was set to skip certain channels. You need to rescan for channels or manually edit the channel list. To manually add channels, press Menu on the TV (or the equivalent key on the Sony remote if you found a code that works). Then use the Up/Down arrows (channel change keys) to select Ch Scan Memory + . Then enter the number of the channel (numerically or up and down arrows). Press + (volume + key) to change the setting from Deleted to Added or vice versa. Since you do not have the original remote, I'm not sure if the Sony remote will match the Reset key of the original remote. Unfortunately without that key being pressed twice, you can't reset the entire channel list and cause the channel search to begin automatically.
The manual for the DS19330 TV is here: . (I'm assuming you haven't recently added cable after only receiving only OTA signals. If you have changed inputs like that, you need to go through the menu and change the source.) Menu > Cable or Air .
I hope this helps.
Jul 27, 2011 | Sanyo Televison & Video
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
Cable will not work unless you subscribe to a cable service
Jun 17, 2011 | Zenith H27E35DT 27" TV
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Olevia not searching channels
try the following..
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q. Why does my TV display "No Signal" or "Channel not in List"? A. Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
  1. Press Source button until Tuner is visible on the upper right corner,
  2. Press Menu button from the remote,
  3. Press Down arrow key until you see Setup, then press the Right arrow key,
  4. Press Down arrow key until you see TV, then press the Right arrow key,
  5. Press Down arrow key until you see Auto Channel Search, then press the Right arrow key,
  6. Press Down arrow key until you see Air (for antenna; select Cable if you have cable service), then press the Right arrow key. The scan process will start.
  7. Wait until the process is complete then you will be able to select the channel you like to watch.
Jul 29, 2009 | Televison & Video
Initial HDTV-322 32 in. LCD Television Logo
113 people viewed this question
Top Initial Televison & Video Experts
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
