Question about Zanussi Dryers
The drum doesn't rotate and a strange buzzing noise occurs
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DRYER?
the drum doesn't rotate and - small_8_20.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
Gas Whirlpoothe drum doesn't rotate and - redarrow.gifion 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.the drum doesn't rotate and - redarrow.gifh_mi Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE;
Posted on Aug 22, 2008
Drum does not rotate
Is it making noises, Humming Buzzing etc.?
You should hope it's just the Belt NOT The motor / pump assembly.
If the belt is broken you should be able to rotate the agitator manually, if not it could be the motor.
Mar 03, 2015 | Washing Machines
My Kenmore Dryer, Mdl #86681800 won't start when hot
The most likely reason it that the electric motor is failing; the thermal protector on the motor is resetting after the motor cools down. The buzzing is due to a locked rotor in the motor while it is overheated.
Another much less likely possibility is that there is excessive drag on the drum causing the motor to overheat because it is working too hard spinning the drum. Excess drag is due to worn rollers, etc.
Try rotating the drum in the CORRECT direction by hand and see if it seems really hard to rotate. You can try this on a friend or relatives machine to see how much drag is normal.
To determine which way is the correct rotation, just start the dryer, open the door and look fast! To test, just turn it in the same direction as it was rotating before it stopped.
Mar 09, 2013 | Kenmore Dryers
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Oct 02, 2011 | Kenmore 63942 Dryer
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Mar 13, 2011 | Dryers
Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Jun 18, 2009 | Dryers
It makes a buzzing noise and will not run
Rotate the drum while holding the door button with the dryer turned on.
Apr 23, 2009 | General Electric DHDSR46EGWW Dryer
Re: Lavamat 72630, 6 yrs old Very loud noise from drum movement, has increased over last ten washes. When machine is stopped, on rotating drum we note it is catching on something. Nothing rattling, don't...
Hiya admin47..... to be a litle more certain diagnosing your problem, please can you do the following.
1. with the washer empty.. ie the drum... please rotate the drum by hand at any speed you can get... without moving the drum sideways/backwards. Listen for any peculiar noises.
2. Then move the drum backwards at the bottom of the door ( dont force).. then let the drum housing go.. swinging by its own movement, again listen for any strange noises.
3. Do the same pushing the drum from the inside to the outer casing..again dont force.. let go listening again...
Please post me the results
Regards Faggly
Mar 18, 2008 | Washing Machines
Dryers Logo
195 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Richard Roth
Richard Roth
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
