Question about Freezers
Hotpoint frost free freezer
My Frost Free freezer is starting to accumulate ice in the bottom Compartment. It also appears to be on more often than it used to be.
  • 639 Answers
Hi angove,
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Posted on Aug 25, 2008
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frost free freezer with ice in the bottom and water dipping off bottom door hinge
Frost Free Freezer have an automatic defrost, which is essentially a heating element which melts any ice. If your door seals are in poor condition or something is preventing the door from sealing the ambient air may be melting the ice more than the drain can accommodate. Check the drain in the bottom of the freezer. Humidity can also cause more water to accumulate, especially if the door seals are not sealing.
Jul 10, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Apr 07, 2009 | Maytag Freezers
Ice is forming at the bottom of the freezer and freezing the bottom draw shut. it doesn't appear to be leaking and the door shuts properly. it's supposed to be a frost free freezer....
Causes:
High humidity in the immediate area causing condensation to freeze at the door opening
A frozen defrost drain line not allowing water to drain off when the unit is in defrost
A bad door gasket causing an air leak
Some freezers have a heated perimeter to reduce condensation. If the stop working, moisture can accumulate arounf the door perimeter and freeze.
Leaving the door open too long or something obstructing the door
Mar 28, 2009 | Freezers
Frost free freezer leaking water everyday. the door and seals are fine. only 3 years old. ice appears in lower compartment.
When the freezer defrosts the water has to go somewhere. The defrost drain is stopped up. Blow it out.
Jan 26, 2009 | Freezers
Frost in Kenmore frost free
Although you say the seal is fine, this is almost certainly due to air getting in. With the door closed check that there isn't a tiny gap with a strip of thin card or plastic. Of course if air is getting in then it must also be getting out somewhere else so probe all around the seal.
Oct 01, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
103 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
